Details of your proposed solution are removed, as those will confuse users.
Yes, indeed the software needs to be installed with admin rights, and it should be done so.
The solution of the error is provided here.. http://www.virtualdj.com/wiki/Invalid%20Skin%20Error.html
geposted Sun 21 Jul 13 @ 4:41 pm
how can i repair "invalid skin file-error line 0 in the xml"
geposted Wed 29 Jan 14 @ 1:15 pm
Come on - read the post directly above yours!!
You could also try re-installing the software, this usually fixes the issue also.
geposted Wed 29 Jan 14 @ 1:24 pm
Hi all, changed my pc as the old one fully crashe. re installed virtual dj le (for usb controller ion discover dj pro ) but cannot open virtual dj as an error message is popping up with invalid skin. i'm not an IT expert and XML is nearly chinese but is ther a way to fix this issue ? best regards
geposted Wed 03 Sep 14 @ 1:47 pm
Probably the LE version is looking for a specific (tailored skin) but cant find or the Home Folder is incorrect.
Please make a clean installation of the LE software , by following this (especially the cleaning registries part) .. http://www.virtualdj.com/wiki/How%20do%20I%20perform%20a%20clean%20re-installation%20of%20the%20software.html
geposted Wed 03 Sep 14 @ 7:04 pm
