| Autor | - Topic: 1680x1040 skins - |
Any of those 1680x1040 skins out there?
Thanks Jamie |
mate i need a skin ...big .....pioner 1000
cheers |
Thanks Jamie Look in my blog, I worked V-Mix 5.3 for you in 1680 x 1040 Give Me news |
Hi pasco!
I saw one 1920x1200 skin on your blog. Is there any change that you could resize video vision 5 skin to 1920x1200? I have tried skin resizer but it always give me xml error :( Here is video vision 5 thread: http://www.virtualdj.com/forums/82609/Skins/VideoVision_V5_Widescreen_1440_Released_.html?highlight=video%20vision |
OK, I am going to try, give me some days |
Thank you so much for your effort pasco! I really do appreciate it. No need to hurry! :)
PS. Somebody give him a vip status! ;) |
ok video vision 1920 x 1200 now available on my blog |
thank you so much pasco for being so helpful! I can't wait to get home and give it a try :)
Thanks |
ok level update |
pasco123 wrote :
ok level update Thank you. I hope you understand why ? |
I'm making a skin with a resolution of 1680X1050 There are 2 DVJ-1000 in it, 3 video screens and an internal mixer. But it takes a while for it's done. |
hola, kiero bajar SKINS PARA MI VIRTUAL DJ., ALGUIEN ME PUEDE AYUDAR,, POR FIS.. MI CORREO ES: --@--.-- -- Moderated by Lady Cameron Sorry felipe_2008 no email address is allowed from a demo user |
Assume you mean 1680x1050 (not 1040! - unless you still want the windows start/channel bar ?)
Ferrari MK2 skin i made is 1680x1050 and has been available for a while now on the download page. If you need it 1040 not 1050, its very easy to change, just need to make browser window slightly smaller, - 1 number change. |
I need a 1680 skin and say the Ferrari skin. It looked like that was only for VDJ 4.0 though?
I am using the latest version of VDJ and screen resolution is 1680 x 1050 so it would be great to use all of the real estate. Just can't find a skin to work. The pioneer skin is a great piece of work, but it's just not for me. Thanks for any info you might have about other 1680 skins. |
I am using the latest version of VDJ and screen resolution is 1680 x 1050 so it would be great to use all of the real estate. Just can't find a skin to work. The pioneer skin is a great piece of work, but it's just not for me. Thanks for any info you might have about other 1680 skins. If I can help you, your screen is a screen 16/9, choose a skin 16/9 and I can help you. Attention, most part of skin Pionneer are 4/3 and cannot be modified in 16/9 because the browser does not work any more. |
Ferrari skin works on latest version. The 4.0 is the minimum version of VDJ required |
This skin http://www.virtualdj.com/addons/skin.html?id=4327 is also 1680X1050 (16:10 ratio) |
