| Autor | - Topic: [NEWS] VirtualDJ 5.0.7 - |
Hello.
Version 5.1 is almost ready, but in the meantime here is v5.0.7. You can now link videos to audio-only songs (drag and drop the video on the skin's video preview window), you have a new button to log requests you couldn't fullfill (in order to download them once back home after the party), a new option to remember manual adjustments on gain, and a new karaoke plugin to manage your rotations and display various messages. Plus some various minor bug fixes. v5.0.7 is also available (and stable) on Mac. |
nice new features
i think there are some new pitch ranges, too still trying to figure out about the log request function... please give us some further details thanx, matt |
Good thing I put this on my tester laptop and not the live rig... http://www.virtualdj.com/forums/84955/PC_version_bugs_report/VDJ_5_0_7_Karaoke_Plugin_Failure.html
Update: solved by installing latest directx 9.0c runtime. Older directx 9.0c installs may need to be updated, however old and new versions still list as 9.0c under dxdiag. |
does it fix the native support for Denon controllers(dh-hc4500, dn-hs5500)? |
No, the denon is not fixed yet (need fix from Denons side) |
Here a summary list
New features: - added +-100% pitchrange in options, action "pitch_range", item "%pitchrange" in skin textzones - new ASIO engine (default engine is when "ASIO UltraLatency" is checked, new engine is unchecked and is safer) - new button to log searches, so you can download after the party the requests you couldn't find - new auto-gain options (auto+remember, remember, auto, disabled) - can drag a video file on the video preview window to link with audio-only files - option in video config to disable link on drop - actions "Video_Link", "Video_Unlink", browser column "LinkedVideo", search option "LinkedVideo", filter items "LinkedVideo", "HasLinkedVideo". - can now unlink video by drag&droping the original file (in addition to context menu option still present) - added "%linkedvideo" in skin textzones - skin slider "round" are automatically rotated if doesn't have . in this case, optional param "minangle", "maxangle" can specify the rotation angles at 0 and 4096 in degree. - new skin object , new actions "multibutton", "multibutton_select" - clipbank plugin can be cloned (clipbank2.dll, etc) - new karaoke plugin - compatible with new Hercules DJConsoles (mobile, Rmx) Fix: - fixed itunes songs with "&" character - fixed accents in itunes folders - fixed pitch/bpm for HC4500 - fixed some minor bugs If someone have problem with Karaoke plugin please Download DirectX End-User Runtimes (November 2007) http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=1a2393c0-1b2f-428e-bd79-02df977d17b8 |
what is this? ->
- new skin object , new actions "multibutton", "multibutton_select" |
I see it is compatible with new the new Herc RMX DJ Console, great. Will it be a matter of just plug and play ( native support ) when the console gets released.
Jimmy b |
Yes Jimmy, new Hercules RMX will have native full support, just only to plug and mix ;) |
Cool Cioce, and thanks :)
Jimmy b |
appreciate the hard work guys! |
What a good little feature, just noticed the button. I had a couple of requests for tracks on Friday night, which I didn't have, Had to write them down on a scrap piece of paper, to grab when I got home, so unprofessional, but with this neat feature it does away with that. Nice Jimmy b |
Is the DAC-2 bug fixed? |
Thanks guys ,will update tonight.
Any chance of Napster being able to connect coming anytime soon? |
Yes the DAC-2 Bug is Fixed ! |
VanStino is heading to the download center. |
Just be carefull with the current DMC2 mapper of jpboggis and pitch=-100%, you could have a crash. But I guess the mapper will be fixed soon by him |
Thanks for this update! cred to the team involved.
Seems to work ok for me. |
good work team... tequila-espresso martini's all around |
djcel wrote :
Just be carefull with the current DMC2 mapper of jpboggis and pitch=-100%, you could have a crash. But I guess the mapper will be fixed soon by him be careful when going to -100% with the dac3 and boggis mapper too! it'll crash!!!! |
