Forum: Virtual DJ Radio - Topic: ..:Help me ı dont broadcat my own radio:..
All about the VirtualDJ radio, 100% live mixes from DJ's around the world!
Tune into our 3 Channels here : http://radio.virtualdj.com
Channel 1 : House, Club, Electro | Channel 2 : Urban, Reggaeton, dancehall | Channel 3 : Progressive, Tech, Minimal, Trance
VirtualDJ Forum
Virtual DJ Radio
..:Help me ı...
Autor - Topic: ..:Help me ı dont broadcat my own radio:.. -
dj_wahwut
Limited edition user
Posted Tue 26 Feb 08 @ 5:07 pm
first hi and ım very bad engılısh,
ı ınstall vdj 5.0 and own my radio no problem ıts workıng this versions.but ı unstall thıs versıon and than ı ınstall 3.4 versıon
but the my own radıo dıdnt work and the 5.0 versıyons lısten started ip:http://88.209......:8000/VirtualDJ.mp3 no problem
but the versıyons 3.4 lısten started ıp:http://192.....:8000/VirtualDJ.mp3
thıs ıp (http://192.....:8000/VirtualDJ.mp3) my pc ip.
8000 port is open my router ??? help me pls ??????
ı want workıng the radio 3.4 versıyon.
Paz75
Experienced pro user
Posted Tue 26 Feb 08 @ 8:36 pm
in VDJ REC screen, what mode are you using "broadcast to a radio server" ... or ... "broadcast from my own computer" ? For VirtualDJ.mp3 you need to set on "broadcast from my own computer"
how do you try to connect? from same computer or from other computer?
check if windows firewall allows port 8000.
also check to connect from local machine before connect from other machine.
dj_wahwut
Posted Wed 27 Feb 08 @ 2:22 pm
ı connect to the other computer
look this image
http://img266.imageshack.us/img266/9083/balksz2kopyari7.jpg
thanks
dj_wahwut
Posted Wed 27 Feb 08 @ 2:52 pm
sorry !!!
ı connect the other computer
look at this image
http://img406.imageshack.us/img406/668/balksz2kopyakopyaxz8.jpg
Paz75
Posted Fri 29 Feb 08 @ 12:47 am
first of all, are you sure that your mikrofon input is the correct one? VDJ will not stream (i found this the hard way) if there is no audio coming in the input.
second, in Windows Firewall, adding VDJ as program is not enough. you have to actually add the port 8000 there.
thirdly, the screenshot of your router, you need to specify somewhere which ip addres that port 8000 is forwarding. make sure that is your local machine;s ip.
for instance, my ip available to the world is 87.200.111.222. but the laptop is 192.168.100.100. so port 8000 is forward to port 8000 on 192.168.100.100.
lastly, why are you using v3.4 anyways? i wasnt around that long, but maybe there was something wrong with streaming back then?
dj_wahwut
Posted Fri 29 Feb 08 @ 8:16 am
yes ım sure ı ınput correct mikrofon,8000 ports added to firefall ı use laptop,thıs ımage ıp my laptop ip ı want to use 3.4 becouse 5.0 versıyons very slower and sound is noise (ı use volume,mid,bass,treble,gain, sound is noise ı goto performance optıon anda safemod and overloack free latency ıs auto sound is noise and than 3.4 versıyons very fast workıng and sound is perfect)
my laptop:
ıntel core duo 2.0 ghz t7200
1 gb ddr 667 mhz
256 mb.ıntel
spun1_2
Ultra-VIP Member
Radio Teamer
Posted Mon 03 Mar 08 @ 2:39 pm
version 3.4 is the home edition that comes with the mk2 console...
if you pay for ver 5 you should use that.. if your having sound problems its most likely due to your settings...
LOVE BRASIL
No license user
Posted Fri 29 Jan 10 @ 7:25 pm
eaew galera tenho uma pergunta aki pra vc's !!
I can not listen to my radio on the virtual line !!
I do??
lbaixinho
No license user
Posted Mon 12 Jul 10 @ 5:46 pm
naum consigo acessar minha pg oq eu faço
Misaktor
No license user
Posted Tue 07 Dec 10 @ 8:05 pm
hola tambien mi ingles es terrible, yo tambien quiero transmitir me servira para un proyecto de la universidad el motivo por el cual les escribo es porque doy la direccion que dice abajo en strart recording, y cuando las personas quieren abrirlo dice que la pagina tuvo un error me gustaria saber cual es el problema, no tengo muchos conocimientos en computacion asi que cualquier ayuda seria buena,,,,hello well my English is terrible, I also want to convey, I will serve for a college project the reason why is because I am writing the address down saying strart recording, and when people want to open it says that the site had a mistake I would like to know what the problem is, I have many computer skills so any help would be good
Haui70
Senior Team
VDJ Radio Team (Germany)
Posted Wed 08 Dec 10 @ 2:26 am
@Misaktor, please write in english or use the Spanish Forum. :-)
http://www.virtualdj.com/forums/12/Spanish_Forum.html
Thx
djdavidbrown
No license user
Posted Mon 31 Jan 11 @ 3:30 pm
Dj David Brown in sesions en 87.221.59.1:8000 sessionacaaaaaaaaa
mc-mauro
No license user
Posted Thu 02 Feb 12 @ 11:19 pm
Eschame desde tu casa Escucha la
http://200.59.226.111.8000/VirtualDJ.mp3
Posted Fri 03 Feb 12 @ 4:14 am
Please do not post here these type of informations!
closed
