| Autor | - Topic: EFFETTI VIDEO E TRANSIZIONI (nuove uscite ed aggiornamenti) - |
Uscito nuovo plugin Video per la visualizzazione delle foto, ATTENZIONE è una beta
SBDJ SlideShow (Beta 1)
Descrizione: Effect A new SlideShow plugin that keeps images aspect ratio correct (according to the output screen resolution). < This version is an initial beta, so test at your own risk. If you have problems, please make sure you have at least Directx 9 November 2007 updates installed. Scratch Worx v1.0
Descrizione: 3-In-1 Transition Chrono Cut: Scratch Cut: Line Fader: Assign your upfaders to video_trans_param 1 and 2 and your crossfader to video crossfader. Scratch Cut: Works exactly the same way as the scratch transition. Line Fader: Works by fading between videos using your upfaders. Chrono Cut: Works by evaluating the speed of your turntable and cutting back to the other video if it slows down below a certain point (which is editable in the transition FX tab: chrono cut sensitivity slider. Push completely to the left to switch off). Revisione: /! If the plugin doesn't work on your computer, please download and install the microsoft update available here Download -> http://www.virtualdj.com/addons/view.html?type=video%20effect |
Disponibile già da un po' di tempo un bel pacchetto di transizioni video per MAC
Descrizione: In this zip file, you will find the following video transitions for the MAC version of VirtualDJ: * Slide3D * Spiral * SizeFall * Curtain * LightFall * Rhombus scaricare il file .zip (download mac) e scompattarlo quindi copiare la cartella della transizione "xxx.bundle" in: /users/"nome utente"/documents/VirtualDJ/plugins/VideoTransition Link diretto al download -> http://www.virtualdj.com/addons/download.html?addon_id=4146 |
Aggiornamento per il plugin per la visualizzazione delle foto SBDJ SlideShow v1.01
Link agli effetti video :-> http://www.virtualdj.com/addons/view.html?type=video%20effect Bye Joe |
Salve a tutti.Finalmente con questo plug-in(SBDJ SlideShow)le slides si aprono nel formato originale.
L'unico problema che ho riscontrato è che,se nel frattempo proietto videoclips,in sottofondo si vede parte della videoclip che stò "suonando". Saluti. |
ciao guarda devi mettere la trasparenza dell'effetto al minimo cosi non vedi sotto la parte della videoclip. ciaoooooo |
@ gianlucadj:scusa ma non riesco a trovare l'effetto trasparenza. Nel pannello del plug-in ci sono solo il ritardo e la risoluzione + i pulsanti slideshow,
transizione ed enlarge small pictures o mi sono perso qualcosa ?(devo forse attivare un altro plug-in?) Ciao e grazie :) |
Infatti questo effetto non è dotato della slide per impostare la trasparenza, forse gianlucadj l'ha provato un attimino in fretta, nel weekend se ho tempo faccio alcune prove e vi so dire. |
