Forum: Old versions
Topic: cant open mp3 encoder - Page: 1
what do i do everytime i try to rec. it saids cant open mp3 encoder
geposted Mon 31 Mar 08 @ 12:10 pm
jimmy bPRO InfinityMember since 2007
I get that, so I record in Wav format, then convert the recording/File back to mp3 after,
it's a ball ache but it works.
Jimmy b
geposted Mon 31 Mar 08 @ 1:11 pm
spinnaJPRO InfinityMember since 2004
Hi jimmy, do u have the lame Mp3 encoder installed on ur PC?
If u have it. once in record config, select MP3 n choose where ur lame dll is placed on ur hdd. If u need it i can sent it to you:)
Or u can download it here from free-codecs.
This goes for u too tech6384;)
geposted Mon 31 Mar 08 @ 3:05 pm
Come to think about it I don't think I have, SpinnaJ. Whenever I've to record in mp3 format, it comes up with lame mp3 encoder error.
Can you send me it please. I'll pm you my Email address.
Cheers mate :)
Jimmy b
geposted Mon 31 Mar 08 @ 6:11 pm
I received ur PM. Will sent it to you once i back at home much later;)
geposted Tue 01 Apr 08 @ 12:55 am
Hi Juan, I already sent it to u n do follow the instruction in the email.
Njoy;)
geposted Sat 26 Apr 08 @ 9:15 am
SpinnaJ,
I've been having the same problem, and nothing is working!
Once you download the lame dll, what do you do next?!
thx!
Nicole
geposted Wed 27 May 09 @ 1:51 am
thx!
Nicole
Hi nicole, the general answer is already given above;)
geposted Wed 27 May 09 @ 12:06 pm
plj667Home userMember since 2009
hey man i do everything as you told above but it keeps on telling me cant open mp3 encoder...
i have unzipped the encoder in the vdj folder in my documents and i save my file in the same folder but the result is the same
please help
thnx in advance
geposted Sat 06 Jun 09 @ 9:22 am
nobody???
geposted Sat 06 Jun 09 @ 5:13 pm
somebody please its urgent
geposted Sun 07 Jun 09 @ 3:42 am
mp3jrickPRO InfinityHonorary MemberMember since 2003
Post the link to the download for the encoder here.
geposted Sun 07 Jun 09 @ 8:41 am
geposted Sun 07 Jun 09 @ 1:19 pm
geposted Sun 07 Jun 09 @ 5:47 pm
geposted Mon 08 Jun 09 @ 3:55 am
DEAR FRIENDS OF COMMUNITY:
AT 1ST I HAD THE SAME PROBLEM WHEN TRYING TO RECORD: "CANT OPEN MP3 ENCODER"
PLEASE, TRY TO FIND THE SOLUTION AT PAGE 57, AT THE USER GUIDE.pdf, ON ACROBAT READER.
- AT FIRST, YOU MUST CLICK ON THE BUTTON "RECORD",
- 2ND, CLICK THE BUTTON CONFIG, BELOW;
- THE WINDOW "RECORD AUDIO CONFIG" WILL OPEN TO YOU;
- SELECT "MP3" AT THE BOTTON OF THE WINDOW;
- THEN YOU MUST FILL INTO BLANK, THE NAME OF THE ENCODER. SO, CLICK THE BUTTON AT RIGHT (...), TO BROWSE THE NAME OF THE ENCODER. YOU WILL FIND THE CORRETC ENCODER IN: "ProgramFiles\VirtualDJ\Pluginsllame_enc.dll"
.Select it.
- Finally, note that the local above, is exactly as shown on page 57, in the user guide.
I had done these steps and now I can record mp3 format.
Good Luck and enjoy this beautifull software!!!
CLAUDIO ZACCUR
RIO DE JANEIRO - BRAZIL
geposted Fri 03 Jul 09 @ 10:08 pm
.Select it.
CLAUDIO ZACCUR
Perfect EXPLANATION , Claudio , Thank You!
geposted Fri 17 Jul 09 @ 3:32 am
.Select it.
CLAUDIO ZACCUR
Bravo! thx alot, ur awsome hahahahahahhah
geposted Mon 19 Oct 09 @ 11:12 am
a friend of mine was messing around with my virtual dj program and messed my mp3 encoder up he erased it thinking it was a file to place the mixes in. how do i retrieve the code back cause now it says mp3 encoder error
geposted Mon 19 Oct 09 @ 5:00 pm
If the file been deleted, you may just download at the given link at several post above;)
geposted Tue 20 Oct 09 @ 9:37 am
95%
