Forum: Hardware Technical Support - Topic: Help with mk2
Please post here all questions or comments about the hardware supported natively or by MIDI with Virtual DJ, Virtual Vinyl, Cue or AtomixMP3.
Hardware products
VirtualDJ Forum
Hardware Technical...
Help with mk2
Autor - Topic: Help with mk2 -
Terakor
No license user
Posted Mon 12 May 08 @ 11:41 am
Hi, first of all sorry for my english, i have seen this picture http://www.etcetera.co.uk/products/images/HER102su2.gif and my question is if i can do the same but WITHOUT the external mixer, just with mk2 2 turntables and the pc.
Thank you.
jimmy b
VIP Member
Posted Mon 12 May 08 @ 11:45 am
Turntables go into inputs 1/2, inputs 3/4
Output 1/2 goes to your amp/PC speakers. Quite simpy really.
Terakor
No license user
Posted Mon 12 May 08 @ 11:47 am
Hi and thanks for answer so fast, excuse me becouse i am new, but i need an amp?
jimmy b
VIP Member
Posted Mon 12 May 08 @ 11:50 am
You don't have to, but the sound quality is better running though a amp, than PC speakers.
Terakor
No license user
Posted Mon 12 May 08 @ 11:51 am
A lot of thanks, you really help me :)
jimmy b
VIP Member
Posted Mon 12 May 08 @ 1:01 pm
No Worries mate :)
Terakor
No license user
Posted Tue 13 May 08 @ 8:01 am
Other question, I think is a bit stupid:
- from the mk2 console to the PC, how many cables are? The USB and the cable from Output 1/2 to the speakers?
DJ-ALF
Moderator
Posted Tue 13 May 08 @ 10:01 am
Nope, just one USB cable connecting MK2 to the PC, all audio cables are on the MK2 itself.
Terakor
No license user
Posted Tue 13 May 08 @ 12:02 pm
Ok so when you want to hear the sound in a amp you need a "special cable" connecting from mk2 to amp; but when you want to hear the sound with the pc speakers, the USB is sufficient, no?
A lot of thanks.
jimmy b
VIP Member
Posted Tue 13 May 08 @ 12:15 pm
A lot of thanks.
mk2 (outputs 1&2) to amp, you want a RCA cable with 4 male jacks.
mk2 to PC speakers, (small output 1&2) small 3.5mm jack (the one on your speakers that go into the soundcard of your PC).
Terakor
No license user
Posted Tue 13 May 08 @ 12:45 pm
Ok, now i understand
A lot of thanks
Terakor
No license user
Posted Thu 15 May 08 @ 10:27 am
MK2 + 2 numarkt tt 500s + mixer will sond good?
If it is yes what mixer do you recomend me?
Thanks.
skyfxl
VIP Member
Posted Fri 16 May 08 @ 4:03 pm
Thanks.
An RMX would be better and a VV box would be even better than that.
Terakor
No license user
Posted Sat 17 May 08 @ 6:49 am
Ok, can I invert the faders of hercules rmx or of the virtual dj program?
DJ-ALF
Moderator
Posted Sun 18 May 08 @ 9:52 am
You can map whatever you want as it is MIDI mixer. There is no Mapper for RMX yet, but soon.
(C)opyright Atomix Productions 2009
VirtualDJ Pro
VDJ HomeEdition
DJC Edition
Trial Version
Sound Effekte
Video Effekte
Tools & Drivers
Users Network
Wiki
Atomix Productions
Disclaimer
Wiki
