Forum: Virtual DJ Plugins - Topic: serato plugin
Post here comments on the Virtual DJ Plugins (Audio effects, Video effects, Video transitions, Devices mapper, Tools, ...).
We remind that plugins are downloadable by registered PRO users only.
VirtualDJ Forum
Virtual DJ Plugins
serato plugin
Autor - Topic: serato plugin -
hochman64
Professional edition user
Posted Wed 14 May 08 @ 2:43 pm
I would like to know what's going on with the serato plugin to use serato vinyl with virtual dj 5.7 because now it's something like 2 months that I work with the VDJ 4.2 which is working very good with the serato box and the serato vinyl and that's so strange that's not working with VDJ 5.7 but the developers are working hard. I feel myself so paintfull that I don't use the new technologie of VDJ 5.7 because librairy of VDJ 4.2 is not so good but I like to scratch with it .... so I Want to introduce myself as a beta tester for the serato plugin please I will work hard on it I make a good test believe me.
cstoll
Atomix Productions
Posted Wed 14 May 08 @ 4:29 pm
Part of your problem is the the timecode engine changed between 4.2 and 5.0 and yes that is why a plug-in would need to be built to provide a better performance in v5.
Please us the search next time - http://www.virtualdj.com/forums/83689/VirtualDJ_Plugins/Timecode_plugin_development.html?highlight=serato
Also, with or without the plug-in - it is still recommend to use the VirtualDJ Timecode. Using other brand timecode is not a guarantee in performance - it is a AS IS performance.
hochman64
Posted Wed 14 May 08 @ 6:10 pm
Ok,I know that post for a long time and I've tried to compil the code vith virtual basic like they suggest in DSK developpers but I didn't succed that was so many error in the compilated code that I begin to understand this is not so easy to do ... I am not a developper, not at all, I can fix the shortcuts on VDJ but there is no way I will fix the universal timecode engine ... I just want to mix and I want to scratch I spend a year with my hercules Mk2 and My virtual vinyl to realise that my problem wasn't the computer but soundcard so after read full of post I bought the serato box witch is one of the best solution according to some post and when I Tried the ssl vinyl that was the touchin'so perfect that now I cannot play with vdj vinyls anymore because it's not workin good first and second the touchin is nothin compare ... believe me , you just have to try , that why I stick on VDJ 4.2 Because it's wonderfull but I can't play My new M4A from itunes that why want to be a beta tester for the universal plugin Yo
SBDJ
VIP Member
Posted Wed 14 May 08 @ 7:52 pm
I might have to buy some Serato vinyls and look into this, seems to be a lot of requests for it...
hochman64
Posted Thu 15 May 08 @ 6:19 pm
--------Also, with or without the plug-in - it is still recommend to use the VirtualDJ Timecode. Using other brand timecode is not a guarantee in performance - it is a AS IS performance---------
I had a doubt for a moment ... So I retry again VDJ 5.5 with VirtualDJ Timecode vinyl
just tried a backspin to realise that the control is limited... For me, VDJ 4.2 with serato vinyl guarantee performance
I Love VDJ and I wish the Team will fix it
cstoll
Atomix Productions
Posted Thu 15 May 08 @ 8:55 pm
So you tried a version that has been updated twice since it's release. What sound card are you using SL1 ? And what TC mode where you using ? Was the Timecode configured or just defaults after activating it ?
hochman64
Posted Fri 16 May 08 @ 7:53 pm
Ok, I will test with VDJ 5.7 and vdj vinyls, my OS is windows XP Pro, I use SL1 sound card, hercules dj MK2 (with mapper) just as midi control for effects and browser + external mixer + 2 Numark TT 500
I use
Relative Mode
Lead time 500
Pitch sensitivty 5000
No Anti skip
No Clear sound
No Smart Cue
No Browse track
Latence auto
Safe Mode Yes
Overclock Yes
Scratch quality
basic interpolation
master tempo Fast
but You know What I mean, if you make a big backspin with VDJ vinyl it doesn't sound, that's why most use the backspin effect to do that
But if you use the A side of serato vinyls it just sound
I'm not playin video and I prefer to mix with VDJ 4.2 to get that touch with the vinyl because it's so close with a real vinyl
I just canot get back to vdj vinyl it would be like go to scratch live after using VDJ just impossible
cstoll
Atomix Productions
Posted Sat 17 May 08 @ 3:35 am
Well relative is not going to give you the backspin effect like you expect. Change to absolute or smart mode.
Pitch sensitivity is way high. Try 2000. Un-check the SafeMode and Overclock.
hochman64
Posted Mon 19 May 08 @ 6:33 am
Ok, i tried what with your settings, it's working better but way far from Serrato, reinstalled 4.2 ( sorry to say that but you have to face the truth ).
I'm gonna wait for those plugins.
VirtualDJ Pro
VDJ HomeEdition
DJC Edition
Trial Version
Sound Effekte
Video Effekte
Tools & Drivers
Users Network
Wiki
Atomix Productions
Disclaimer
Wiki
