Forum: Hardware Technical Support - Topic: RMX Sound Blips
Please post here all questions or comments about the hardware supported natively or by MIDI with Virtual DJ, Virtual Vinyl, Cue or AtomixMP3.
Hardware products
VirtualDJ Forum
Hardware Technical...
RMX Sound Blips
Autor - Topic: RMX Sound Blips -
duble F
Limited edition user
Posted Thu 15 May 08 @ 5:54 am
Hello there. Took delievery of my RMX this morning and gave it a little testing. One thing i noticed was that after about 4-8 bars of music, there was a split second loss of sound. It was pretty annoying. Is there anyway of getting rid of that.
And i might be a complete idiot, but i can't manage to get the faders to work. I've put the 'Monitior' knob to mix, but the faders don't respond at all. Any ideas. I was too use to the MK2, so this might take some time.
Cheers
duble F
Posted Thu 15 May 08 @ 8:56 am
Managed to get the faders working, just changed the output channels, but i've still got the blips. Any ideas what settings to use in the performance tab?
Cheers
jimmy b
Experienced pro user
Posted Thu 15 May 08 @ 9:00 am
Preset slider all the way to fastest, latency on Auto.
duble F
Posted Sat 17 May 08 @ 12:32 pm
I tried this, but the blips still happen regulary. My laptops specs aren't bad so i dont think its that, but are there any other settings i could try?
Cheers.
tayla
VIP Member
VDJ radio fan
Posted Sat 17 May 08 @ 12:37 pm
you could try this http://www.virtualdj.com/forums/90108/PC_Version_Technical_Support/Audio_Output_-_Slight_Pauses.html it may help
shame on you jimmy did we forget... to much shopping eh
DJ-ALF
Moderator
Posted Sun 18 May 08 @ 9:28 am
You might have problem with IRQ conflict, can you try using some other USB port? If you have some other USB devices like mouse or external hdd, try without them.
VirtualDJ Pro
VDJ HomeEdition
DJC Edition
Trial Version
Sound Effekte
Video Effekte
Tools & Drivers
Users Network
Wiki
Atomix Productions
Disclaimer
Wiki
