| Autor | - Topic: RMX Sound Blips - |
Hello there. Took delievery of my RMX this morning and gave it a little testing. One thing i noticed was that after about 4-8 bars of music, there was a split second loss of sound. It was pretty annoying. Is there anyway of getting rid of that.
And i might be a complete idiot, but i can't manage to get the faders to work. I've put the 'Monitior' knob to mix, but the faders don't respond at all. Any ideas. I was too use to the MK2, so this might take some time. Cheers |
Managed to get the faders working, just changed the output channels, but i've still got the blips. Any ideas what settings to use in the performance tab?
Cheers |
Preset slider all the way to fastest, latency on Auto. |
I tried this, but the blips still happen regulary. My laptops specs aren't bad so i dont think its that, but are there any other settings i could try?
Cheers. |
you could try this http://www.virtualdj.com/forums/90108/PC_Version_Technical_Support/Audio_Output_-_Slight_Pauses.html it may help
shame on you jimmy did we forget... to much shopping eh |
You might have problem with IRQ conflict, can you try using some other USB port? If you have some other USB devices like mouse or external hdd, try without them. |
