| Autor | - Topic: TIMECODE HELP /// Can torq tcv work with virtual dj??? - |
Hey, I have been using virtual dj for about a year and love it. I recently bought a connectiv soundcard with torq and tcvs, I love using timecoded vinyls for external control, but the torq interface SUCKS. I would really like to use timecoded vinyls to control virtual dj, but I can't find the replacement vinyls anywhere. I tried using the torq vinyls with virtual dj, but the pitch is about 20% higher than it should be. So I was curious about a few things... Torqs vinyls obviously do not have the right timecode for virtual dj, but I was wondering if there was any way I could tweak the timecode so it could work properly? Do serato vinyls work with virtual dj? and are the Numark Virtual Vinyls exactly the same as virtual djs? It would be dope to rock one of these babies with virtual dj. so pretty. ![]() |
Please do not make multiple posts and please use the search features in the forum - this has been discussed numerous times. Numark VV Timecodes and VirtualDJ Timecodes are the same. Serato partially supported. All others - do not function with VirtualDJ. |
