Forum: Virtual DJ Plugins - Topic: Denon HC4500 and CUE
Post here comments on the Virtual DJ Plugins (Audio effects, Video effects, Video transitions, Devices mapper, Tools, ...).
We remind that plugins are downloadable by registered PRO users only.
VirtualDJ Forum
Virtual DJ Plugins
Autor - Topic: Denon HC4500 and CUE -
aparson
VIP Member
Posted Thu 15 May 08 @ 9:27 am
Hi all,
Can someone tell me if there is a plug-in or mapper that I can use to be able to work my Denon DN-HC4500 with Numark CUE ? Something that will make it work just like VDJ does.
Thanks...ap
tomvassie
Professional edition user
Posted Thu 15 May 08 @ 10:33 am
JP Boggis mapper is in the external tools download's NOW!! its The Muts Nuts!!! you have to try it!!
cstoll
Atomix Productions
Posted Thu 15 May 08 @ 11:44 am
The HC-4500 is not directly supported in the Numark product. It is supported through MIDI control mappings using the MIDI capabilities in CUE.
aparson
VIP Member
Posted Fri 16 May 08 @ 12:44 am
Cstoll,
Could give me some directions on this...I did download his mapper ( a .dll file ) and installed in the appropriate folder...according to the instructions...when I click activate MIDI...the MIDI icon on the remote control tab turns green..however, the controller stays dead...
I did the same procedure on a VDJ demo version, except that this time I click the actual pix of the HC4500...and it worked perfect !!!
Do I need a .html file in addition to the .dll that comes with the package ? Do I need to build my own ? If so, how ?
In the meantime, I'm using the controller with VDJ's demo...this will get me through this weekend at least.
Thanks for your time.
SBDJ
VIP Member
Posted Fri 16 May 08 @ 6:50 am
aparson wrote :
Cstoll,
I don't have Cue, but I think he's saying that the Numark version doesn't natively support the Denon controller, so JPs mapper won't work...
cstoll
Atomix Productions
Posted Fri 16 May 08 @ 10:14 am
That is exactly my point. Custom Mappers are not supported unless their is Native Support already (there is an icon for the controller). Numark CUE users currently have to use the MIDI Configuration in the Remote Control tab and map their own actions to each button of the controller.
aparson
VIP Member
Posted Tue 20 May 08 @ 8:37 pm
Not an issue anymore...I'm now with VDJ.
That's what I should have done from the get-go last year....lesson learned.
Thank you anyway for replying to my previous posts.
ap
(C)opyright Atomix Productions 2009
VirtualDJ Pro
VDJ HomeEdition
DJC Edition
Trial Version
Sound Effekte
Video Effekte
Tools & Drivers
Users Network
Wiki
Atomix Productions
Disclaimer
Wiki
