Forum: MAC Version Technical Support - Topic: Random freezing suddenly began on mac using numark icdx
All about Virtual DJ, Virtual Vinyl, Cue for mac, and mac discussions in general.
VirtualDJ Forum
MAC Version Technical...
Random freezing...
Autor - Topic: Random freezing suddenly began on mac using numark icdx -
djlongside
Professional edition user
Posted Fri 16 May 08 @ 10:58 am
Can someone from the VDJ Team please answer my ticket that I posted since Sunday May 11th. Please.....
skyfxl
Experienced pro user
Posted Fri 16 May 08 @ 4:07 pm
Unfortunately there are only 2 teamers with macs and they are working on betas so it may be a little while.
As your inquiry is regarding a Numark product feel free to contact me via pm and i will try help you out.
Or you could post the issue here and hopefuly we can help you out.
JoshsJams1
Posted Fri 16 May 08 @ 5:57 pm
I am experiencing the same thing. I am using a mac book pro with a DJio sound card. I get intermitten(SP) music drops. this was never like this. I have tried 5.0 and 4.3 and both do it?
Can you help me with this?
At weddings it is really bad cuz it always happens at the worst times.
Thanks In Advance
djlongside
Posted Fri 16 May 08 @ 8:58 pm
Last weekend virtual dj 5 started freezing randomly in the middle of songs, both mp3, and m4a. I was doing a wedding and this was quite embarrassing. It continued freezing randomly on Friday at a club that I play to. I am using numark icdx\'s. Why is this happening? By the way I took virtual dj off my macbook pro and also took my leopard os off, then put it back on, and re-downloaded virtual dj. This did not solve the problem, because last night the random freezes occurred again. Please help me fix this problem. I have a gig tonight and my confidence is very low right now.
Regards.
Longside.
djcel
Senior Team
Posted Sat 17 May 08 @ 7:38 am
Are you using a USB hub?
Be sure to use the right USB port on your MAC and not the ones which cause trouble
skyfxl
Posted Sat 17 May 08 @ 7:55 am
Thats solved in 10.4.11 +
skyfxl
Posted Sat 17 May 08 @ 7:57 am
Thanks In Advance
OSX 10.4 or 5?
A leopard driver and a better tiger driver is on its way and should be out soon.
I would advise you to go to Config > performances and set fastest and auto latency.
skyfxl
Posted Sat 17 May 08 @ 8:08 am
djlongside wrote :
Last weekend virtual dj 5 started freezing randomly in the middle of songs, both mp3, and m4a. I was doing a wedding and this was quite embarrassing. It continued freezing randomly on Friday at a club that I play to. I am using numark icdx's. Why is this happening? By the way I took virtual dj off my macbook pro and also took my leopard os off, then put it back on, and re-downloaded virtual dj. This did not solve the problem, because last night the random freezes occurred again. Please help me fix this problem. I have a gig tonight and my confidence is very low right now.
Regards.
Longside.
What mac do you use?
Which sound card?
djlongside
Posted Mon 19 May 08 @ 8:46 am
I use a macbook pro 15 inch
2.2 Ghz Intel Core Duo
2Gb 667hz DDR2 SDRAM
The default audio card is being used, being used.
By the way, the problem stopped. I think that I solved it by choosing to add my music and video folders to the search data base everytime I start virtual dj for a function, even if I didn't adjust or add any new songs. This is a bit frustrating to have to do this, but its worth the few minutes that it takes. Just don't be running late for a function and forget to do this.
When is the new update coming out? With all of the tweaks that would bring this closer to a perfect program? I like VDJ.... all my colleagues use Serato and they eagerly wait to point out flaws in VDJ performance. I haven't given up yet, I just hope that we can hurry get all the fixes and effects including the full screen resolution right soon. The summer parties are upon us.
Regards.
Longside.
JoshsJams1
Posted Tue 20 May 08 @ 12:51 pm
I am using OSX 5. Please help me!!
skyfxl
Posted Wed 21 May 08 @ 6:43 am
Ok the 10.5 driver for the DJ.io is being improved at the moment we hope to get it out very soon its been delayed a bit unfortuantely due to a couple of issues as we want it to be perfect.
JoshsJams1
Posted Sat 24 May 08 @ 11:57 pm
Is it out or when is it expected??
skyfxl
Posted Sun 25 May 08 @ 12:39 pm
Today my good man , you can get it here www.numark.com/djio
djlongside
Posted Sun 25 May 08 @ 1:49 pm
Ok, so I thought the problem was solved with the freezing, but it wasn't. In the middle of a song or video, the players would just freeze and begin stuttering like, "ah ah ah....". I tapped the icdx, and guess what?... the music resumed. I have updated the firmware on both players and cleaned my computer of it's OS, and reinstalled. The problem is not solved. I can also see that vdj has very low cpu usage, so I know that my high powered mac is not the problem. This sadly seems like a compatibility problem between vdj and the icdx. Please help. I have a busy week coming again and can't spare too many more embarrassing moments.
Regards,
Longside.
VirtualDJ Pro
VDJ HomeEdition
DJC Edition
Trial Version
Sound Effekte
Video Effekte
Tools & Drivers
Users Network
Wiki
Atomix Productions
Disclaimer
Wiki
