Forum: PC Version Technical Support - Topic: ver 5 autoplay serious issue
Ask here any technical questions about the functionalities of Virtual DJ, Virtual Vinyl, Cue or AtomixMP3.
VirtualDJ Forum
PC Version Technical...
ver 5 autoplay...
Autor - Topic: ver 5 autoplay serious issue -
djtops
Professional edition user
Posted Fri 16 May 08 @ 10:19 pm
as a mobile dj I occassionally use the automix function. If I load a dozen songs from my 80's folder and then switch (via the explorer window) to my 90s folder , all the 80s songs VANISH from the automix window!!! How can I load tracks from multiple folders and have them remain in the autoplay "cue"? Dont recall this being a problem on earlier versions.
discjockeydoc
Experienced pro user
Posted Fri 16 May 08 @ 11:14 pm
Go to config>options and set "autoload playlists" to disabled.
What happens when this feature is enabled is that the playlist is cleared when you navigate away (in case you were going to your playlist folder to load one), so that it loads the intended playlist instead of adding to tracks that were left (or intentionally placed) there.
This should fix you up ;)
djtops
Posted Fri 16 May 08 @ 11:24 pm
Thanks DJ Doc, will give it a try....
djtops
Posted Mon 07 Jul 08 @ 9:17 pm
yep, that fixed me up.....thanks for the advise.....sorry i had a brain poop on that one
VirtualDJ Pro
VDJ HomeEdition
DJC Edition
Trial Version
Sound Effekte
Video Effekte
Tools & Drivers
Users Network
Wiki
Atomix Productions
Disclaimer
Wiki
