| Autor |
- Topic: 2 small bugs in playlist - reproducable - |
Posted Sat 07 Jun 08 @ 5:09 pm
Bug 1) Left click some song in playlist Click on some song in playlist (don't use the menu) The original song disappears for a moment...nothing special to worry...but it is enoug to force the song to reload if it is next to play in automix... Maybe it can be critical in certain situations?
Bug 2) I have playlist (letters stand for song names): A B C D E C F . . I am playing the 4th song (=D). I dblclick the 3rd song (= C) to play it But the 6th song (also C) start to play... |
Posted Sat 07 Jun 08 @ 6:21 pm
Which version are you testing? |
Posted Sun 20 Jul 08 @ 1:16 pm
5.07 |
Posted Sun 20 Jul 08 @ 1:21 pm
Another bug:
- playing automix in deck 1 - load the currently playing song to deck 2 (wanna check the exit point options) - rightclick the [BPM] - selecting edit automix tab...it refers to deck 1 instead of deck 2 |
