Forum: PC Version Technical Support - Topic: Problem with MK2 not using channels correctly - Solution
Ask here any technical questions about the functionalities of Virtual DJ, Virtual Vinyl, Cue or AtomixMP3.
VirtualDJ Forum
PC Version Technical...
Problem with MK2...
Autor - Topic: Problem with MK2 not using channels correctly - Solution -
DJ CHOPSTIX
Professional edition user
Posted Sun 08 Jun 08 @ 1:14 pm
Ever since upgrading to Vista 64 bit, I have had an issue with it either outputting a full volume signal to my external board or not outputting through the headphones. I also had issues with it wanting to output to the computer's soundcard (though being controlled by the MK2)
It's a bug somewhere in the MK2's drivers. Go into Config-->Sound Setup tab-->Select the "wrong" setup under output channels. (ie headphones on channel 1/2 and output on 3/4). Click OK....
Now open it back up and change it back :) That's it. Not positive if it's in VDJ's interface with the MK2 or the MK2's drivers for sure.. but it's a simple fix. Hopefully this helps someone down the road.
MadMannixx
Posted Sat 05 Jul 08 @ 4:18 am
That doesn't work for me. I tried that. Will upgrading to 5.1 solve the problem? I am currently running 5(1).0.7. I hear there are major problems with beatmatching in this new version and am hesitant to upgrade with a major gig on sunday. Any other help?
VirtualDJ Pro
VDJ HomeEdition
DJC Edition
Trial Version
Sound Effekte
Video Effekte
Tools & Drivers
Users Network
Wiki
Atomix Productions
Disclaimer
Wiki
