Forum: PC Version Technical Support - Topic: This function doesn't work any longer with VDJ 5.1
Ask here any technical questions about the functionalities of Virtual DJ, Virtual Vinyl, Cue or AtomixMP3.
VirtualDJ Forum
PC Version Technical...
This function...
Autor - Topic: This function doesn't work any longer with VDJ 5.1 -
sischo
Experienced pro user
Posted Thu 19 Jun 08 @ 7:12 am
I noticed that the function "NUDGE" by the skin doesn't work in VDJ 5.1 (I mean by the mouse onto the skin).
I tried it in VDJ 5.0.6 and it works greatly
I write .xml code of the skin that I'm using
######################## Channel 1
## Jogwheel - Channel 1
## Scratch - Channel 1
I hope we can fix it soon
sischo
Posted Fri 20 Jun 08 @ 6:51 am
I hope you've understood explanation of mine
eLeDuSH
Limited edition user
Posted Mon 23 Jun 08 @ 6:12 am
and fixit same problem a-trakt skin
sischo
Posted Mon 23 Jun 08 @ 6:24 am
Your answer doesn't fix my issue.
I know xml file needs logo instruction but that I wrote was a part of whole xml file; I related only that to identify where is the only problem in xml
sischo
Posted Fri 27 Jun 08 @ 5:15 am
I'll try to explain better what I noticed:
with this skin
http://www.virtualdj.com/addons/skin.html?id=2755
After downloading that, push the button NUDGE like showed in the picture (number 1).
Then put the mouse's control onto the black dot (number 2) and pushing the left button of the mouse, move the mouse on the left or on the right.
You can try these actions with version 5.1 and with previous version: you'll surely notice the difference
(C)opyright Atomix Productions 2009
VirtualDJ Pro
VDJ HomeEdition
DJC Edition
Trial Version
Sound Effekte
Video Effekte
Tools & Drivers
Users Network
Wiki
Atomix Productions
Disclaimer
Wiki
