Forum: PC Version Technical Support - Topic: Major problem on 5.1 and CDJ-400
Ask here any technical questions about the functionalities of Virtual DJ, Virtual Vinyl, Cue or AtomixMP3.
VirtualDJ Forum
PC Version Technical...
Major problem on...
Autor - Topic: Major problem on 5.1 and CDJ-400 -
cinfx
VIP Member
Posted Fri 20 Jun 08 @ 9:48 am
HI,
i am using VDJ 5.1 on Windows Vista service pack 1 ( 2gb of ram and a Turbo cache of 1gb ). I was mixing live with this laptop for 6 months without any problems. I was previously using Numark ICDX to control Version 5.07 and it was VERY easy and fun.
With the new CDJ-400,it is now not fun. I am using the CDJ-400 as soundcards since i've upgraded my firmware. BUt in Virtual DJ, i have now hiccup in playback so it is now impossible to mix to songs together because sometimes it's deck one that will hiccup when number play perfectly..Sometimes it's the problem goes to deck 2..Weird and unusable.
Who can help?
Best regards
Eric
djcel
Senior Team
Posted Sat 21 Jun 08 @ 12:40 am
Check your USB bandwidth
kmxorbit
Professional edition user
Posted Sun 07 Sep 08 @ 9:35 am
How do you do that? (checking USB Bandwidth) and what do you need to see?
cioce
Moderator
Posted Sun 07 Sep 08 @ 9:57 am
djcel
Senior Team
Posted Sun 07 Sep 08 @ 11:44 am
In Windows, go to your hardware management. Then open the USB section. Right Click on a sub items and select properties. You will find data about power and bandwidth used.
(C)opyright Atomix Productions 2009
VirtualDJ Pro
VDJ HomeEdition
DJC Edition
Trial Version
Sound Effekte
Video Effekte
Tools & Drivers
Users Network
Wiki
Atomix Productions
Disclaimer
Wiki
