Forum: Old versions
Topic: SLIDESHOW HELP!!!
I have the trial, i would love the full but everytime i go to use slideshow it messes up the picture and blurs it, or decodes it wrong.
HELPP!!!
geposted Sun 22 Jun 08 @ 1:33 pm
There is a plug in u can get after you purchase that fixes that!
IS there a wayi could smaple the plugin with out buying it.
Because if it doesnt work im out 300$.
XmorgasumX
unfortunately you can't mate, but i can tell you that it does work and you def' won't be out $300, plus you get to use all the other goodies in the download section and any other future updates of the software for free... now is that a great deal or is that a great deal
if you go here
https://virtualdj.com/forums/75309/VirtualDJ_Plugins/Slideshow_picture_stretched_V5__SOLVED_.html?page=15
you will see the full history of this particular plug in from it's inception to being a full working utility, there's 15 pages there so you might want to skip one or two... lol
Is there a way Some one could e-mail it to me?
Because i have had thing like this happen, like where some one says "Like if you buy the full version, it'll work." and it hasn't.
if you can.
My email is. --@--.--
~Thanks, Morgan.
Moderated by Lady Cameron
Sorry XmorgasumX no email address is allowed from a demo user
no one is going to email you the plug in. I suggest you buy and register the software you won't regret it, This forum is great lots of helpful people here will assist you, and VDJ tech guys do a great job as well
Could i possibly find it on a different site?
the plug is only for registered users.
Right, i know that.
But i found it on a different site, couldn't i download and it'll work?
If you found the pluggin on another web site then we cannot offer you any support of it officially. Please support the software by purchasing a fully licensed Pro version as soon as possible.....Thanks, hope to see you as a Pro user soon...
Ohh, alright.
Ill try to buy it soon.
I did find numark cue for 150$
Thats the same thing right?
At this time yes CUE and VDJ are essentially the same program I own both and have seen no difference.
XmorgasumX
before purchasing the software please make sure whatever your going to use it with comes up to minimum specs and it has a dual video processor, will save a lot of heartache... and i stand by what i said, you won't be disappointed
Tayla
Heres what i have.
2.2 GHZ dual core.
1gb video card (ati) Upgrading to nvida next week :)
2gb of ram
500 gb HD
XmorgasumX wrote :
Heres what i have.
2.2 GHZ dual core.
2gb of ram
500 gb HD
VirtualDJ and all the plugins should run great on that Spec, mate.
Ohh, alright.
I wondered if the slow processor might not be the best
