| Autor |
- Topic: Vista - No Names in fields for Loop Sampler and Effects - |
Posted Tue 24 Jun 08 @ 2:32 pm
I tried to search and see if this had already been reported, it's sort of a weird one. There are no names in the fields for my loop sampler or effects on any deck or video. You can click and get the drop down menu to choose which effect you want or loop, but the name doesn't show up in the field. The field remains blank, but yet it does activate the appropriate effect, etc. when clicked on.
Anyone else have this problem, any solutions?
I am running Vista on a 2.5ghz Dual Core Intel, 4 gb of RAM, ATI 3650 video card. This is the first time this has occurred. THanks for any info anyone might have on this.
Posted Wed 25 Jun 08 @ 6:30 am
Verify that you have the Font used by the skin and reboot your computer. |
Posted Wed 25 Jun 08 @ 8:20 am
How do I make sure that I have the font? The skin I was using was one of the Cue skins.
This is a good question though. When I get home I will have to reboot and see if this problem existed in any of the other skins, I can recall if I checked that out. |
