Forum: Old versions
Topic: WM Encoder Help
Hi, I DJ for a site that uses Windows Encoder to broadcast. I just got my RMX and want to start using it with Virtual DJ. However, after I select it as the sound card to use in encoder, it doesn't play anything. I can hear my cue and everything plays fine through my studio monitors but the sound won't broadcast. Nor do I see the level (green/yellow/red) bars moving. When I click mixer, it says it's not setup yet and to go into control panel to set it up. When I go there, it says the device IS working properly. Anyone use this or a similar setup that can help me out here? Does it have anything to do with ASIO settings?
geposted Sun 29 Jun 08 @ 11:32 pm
hay dj
geposted Sun 12 Feb 17 @ 5:38 am
hi
geposted Fri 31 Mar 17 @ 5:16 pm
