Forum: PC Version Technical Support - Topic: Networking 2 laptops via ethernet
Ask here any technical questions about the functionalities of Virtual DJ, Virtual Vinyl, Cue or AtomixMP3.
VirtualDJ Forum
PC Version Technical...
Networking 2...
Autor - Topic: Networking 2 laptops via ethernet -
jack0161
No license user
Posted Sat 05 Jul 08 @ 10:04 am
Need help setting up the network settings so that two laptops can be linked together, using a crossover ethernet cable between the two laptops.
What do we need to do to enable synchronisation?
djcel
Senior Team
Posted Sat 05 Jul 08 @ 10:33 am
Select "Network synchronysation"
It works like a server-host
=> The host needs to know the IP of the server
(verify that the port is not locked by the firewall)
Then use the beatlock to synchronyse
jack0161
No license user
Posted Sun 06 Jul 08 @ 8:11 am
How do i find the IP address and port number?
SSD-RaveDave
Professional edition user
Posted Sun 06 Jul 08 @ 8:50 am
start -> run -> cmd -> ipconfig
will show your ip. Might want to consider changing your IP to something static in tcp/ip config to make life easier.
turn off your firewall (software) so the port doesnt get blocked
start -> run -> services.msc
look for things like Windows Firewall, Windows Defender, Zone Alarm, or whatever you may have installed.
personally, Ive never tried this feature. I think i might though....
(C)opyright Atomix Productions 2009
VirtualDJ Pro
VDJ HomeEdition
DJC Edition
Trial Version
Sound Effekte
Video Effekte
Tools & Drivers
Users Network
Wiki
Atomix Productions
Disclaimer
Wiki
