| Autor |
- Topic: HELP! I always se green stripes when i mixing video files in vdj 5.1 - |
Posted Mon 14 Jul 08 @ 2:08 pm
Hi! I have some problem when I mix video vob files. Some green/red stripes shows at the window. this will desipere when i close the hardware acceleratin in the video consol, but then I cant use my mix effect´s.
I use Geforce 7900 GTX.
/Karrobarro |
Posted Sat 02 Aug 08 @ 2:06 pm
Had the same problem was using the ati 3870 video card, against the wishes of my computer builder. He warned me that ati's high end cards were problematic. I decided to not play videos for a while, so I could still have the vid effects. 3 weeks later my computer started crashing several times during a night. I pulled the ati and replaced it with the gtx 8800. Everything works great now. Ati card must have been bad. You might have a bad video card. I had orginally benchmarked my computer using futuremarks 3d benchmark 2006 version scored a 9300 just bench it agian last night with the new card and scored over 15000. good luck |
Posted Sun 03 Aug 08 @ 5:16 am
Posted Sat 13 Sep 08 @ 3:52 am
convert your vob files to mpeg2. VOB files have alot of extra encoding that you don't need and just bogs the VDJ engine down |
Posted Sat 13 Sep 08 @ 7:01 am
Music videos generally don't use any of the VOB extras, I can't imagine there would be any tangible benefit in converting? |
