| Autor | - Topic: hercules dj console rmx and virtual dj 5 for mac - |
Beat matching is most often off by a fraction resulting in having to constantly push the - or + of the pitch bend throughout the mix. For instance track A is 123.14 pushing sync on track B (originally at 125.00) makes it 123.15. The record feature make the application crash. I kept using 5.0LE. Now virtual dj 5.2 Pro came out, and I downloaded the software full of hope. its worse now . One of the problems is with the mapping of the hardware software. none of the \"programable keys\" 1,2,3,4,5,6 on the console do what they are supposed to do. Please help Thanks Luc Benech by the way the mac version is OSX 10.5 |
same need here. need to map those key's ! |
djluckyb wrote : Beat matching is most often off by a fraction resulting in having to constantly push the - or + of the pitch bend throughout the mix. Same problem is present in PC version :( http://www.virtualdj.com/forums/93792/General_Discussion/Sorry_Team__first_major_moan_of_5_2_(pitch_bend)_with_Hercules_RMX.html |
Wonder if this has been updated or addressed- seems like there no response from manufacturer.. |
It has been fixed in the last 5.2.1 version |
