| Autor | - Topic: Problem using 2 soundcards - |
Hi Mac users I got a very annoying problem when using the trial version of Virtual DJ 5.2 I got 2 situations, both with the same result: 1. Using my Bose Companion 5 speakers These speakers use a USB output, so normally I should be able to select 'headphones' at the outputs section. Then I selected 2 cards. But when I select my speakers, a very ugly sound like 'bbbgrrrsggggrrrbbbzzz' comes out very loudly. It won't stop when I play music, and I get the same when I connect my headphones. 2. Using an external audio device: Hercules USB 5.1 Channel Well, actualy I purchased these and hoped that they would solve the problem. Unfortunately, the 'bbbgrrrsggggrrrbbbzzz' sound is also in this case. I went to the Apple shop, and they told me it was Virtual Dj's fault. I hope someone knows how to solve this problem, so I can purchase the full version of Virtual Dj. The apple shopmanager is also a Dj, and he told me to buy the Serato scratch. Well, this solution is much cheaper :D I've got the MacBook Pro 2,5 GHz intel core2duo model, running Mac Os X 10.5.4 Thanks in advance! |
Hi Novix, R u running on bootcamp cos as i aware right now is u running on mac osx, there are no trial of VDJ just yet. What r u trying to achieve n what is ur sound set up? Regards. |
A friend of mine gave me the copy, he said it was a trial... Anyway, if I'm going to use it, I'll purchase it. And I'm serious about that. So I got: Setup 1: Virtual DJ 5.2 (the program says it can't be upgraded) which runs on Mac os X 10.5.4 Macbook Pro 2,5 GHz Bose Companion 5, connected with USB A headphone, connected into the 3,5" mm jack into my laptop and a screen of my settings http://i33.tinypic.com/2h3wme0.png Setup 2: Virtual DJ 5.2 which runs on Mac os X 10.5.4 Macbook Pro 2,5 GHz External USB soundcard (Hercules USB 5.1 Channel audio adapter) A headphone, connected into the 3,5" mm jack into my laptop OR into a second port in my soundcard screen of my settings http://i33.tinypic.com/2w32kpg.png |
Hi, try this first.. Can u try only using the internal card solely... does it have a decent sound? As far as the bose companion 5, im not so sure abt that but for ur herc can u just use it as the only soundcard.. Select 4-out card in the soundcard panel. Any better? Sorry i a bit rush over here, tell me how its go n i try to get back to u soon. Regards. |
