| Autor | - Topic: RMX 6+6 buttons config v1.0 by DJCel for Virtual DJ 5.2 - |
A mapper for the rmx would be great , heared about some one is on it yet. Thanks . J |
I think alot of people are waiting for a mapper |
Easy, just download http://www.virtualdj.com/addons/4830/RMX_config_.html & map ;) |
i the mac version coming also ?! |
For give me for being abit thick Cioce, but say if I want to change 4 button action, then I have to have 4 plugins. The decriptive is not all that clear, thanks. |
Thats what it looks like to me from the description :) |
RMX config v1.0 by DJCel Compatibie VirtualDJ 5.2.1 Attention: This TOOL is an audio effect and it require a skin with dedicated slot multibuttons like for example: Vinyl Scratch variations (Scratch5:Basic_Gray(1280x800) v2) http://it.virtualdj.com/addons/4369/Vinyl_Scratch_variations.html or latest Hercules RMX http://it.virtualdj.com/addons/4554/Hercules_RMX_variations.html Follow this procedure to map the buttons: 1) Download and install RMX1.exe 2) enter into the folder C:\Documents and Settings\Digital\Documenti\VirtualDJ\Plugins\SoundEffect copy for 12 times the dll and rename like: RMX1.DLL RMX2.DLL RMX3.DLL ...... RMX12.DLL 3) open Virtualdj and enter in the effects zone, click on RMX1 and select the action (shortcut): ![]() 4) load the effect into the slot (right click and select) ![]() Fx1= button 1 RMX Fx2= button 2 RMX Fx3= button 3 RMX Fx4= button 4 RMX Fx5= button 5 RMX Fx6= button 6 RMX 5) Follow the same procedure for the other deck. Download -> http://www.virtualdj.com/addons/4830/RMX_config_.html raynordinho wrote : i the mac version coming also ?! I don't know. @ jimmy b Waiting for a beer :)))) Thanks to DJCel for the tool and to Moramax for the print screen ;) |
cioce wrote : @ jimmy b Waiting for a beer :)))) It's in the post mate ;) Thanks Cioce, I undersatnd now mate. I will try it out after the weekend. |
Yes the code is MAC compatible that's why I used this solution. I have started a new version of this plugin which is easier to use and avoids to copy the dll. As soon as i can do it, I will finish and compile it for PC & MAC. |
Hey There i didn't quiet figured it out how to put the effects in to my rmx ?? cause i don't quiet understand the discription .... I Followed all of the steps and got stuck on the 3rd one, because i can't open the slots to put in any of the FX .... Can someone help me out? Thnx |
jje vna pregvnta se pveden descargar los efectos? Please don't SPAM, otherwise your account will be LOCKED! |
hello so thanks a lot for this plugin. My buttons work great with the new Version. A big thanks to Dj Cel who made the Plugin and to Cioce for the nice explantation. Ps: Armin and i will make a german explantation for our forum users :-) |
Hey, could you make your plugin that it works like the "RMX Button Configurator" from moramax?? I dont want to use an other skin to make this work. Ill just use the "Internal Mixer" Skin. The RMX Button Configurator doesnt work with newer Versions than 5.1 ;-(( cu pOpY |
tell me a license code, please. i can't download plugins from this site |
A licence is here http://www.virtualdj.com/buy/index.html ;) @ pOpYDJ Sorry but fot the moment this is the only way to MAP the 6+6 buttons with VDJ 5.2. |
thank you, cioce! |
Hi i'm able to map the buttons but when i close VDJ the mappings are lost. Is this the case for everyone or am i doing something wrong?? Cheers |
Thats not good news ;-( The RMX Hardware works very well, but it seems nobody would write a REALLY mapper ;-( cu pOpY |
For what I know the best "mapper" teamer (Moramax) is at work to release a mapper ;) |
thank you cioce!;) yes, i'm working on an optimized mapper for the Hercules RMX. |
