Forum: PC Version Technical Support - Topic: timecode, no signal, please help
Ask here any technical questions about the functionalities of Virtual DJ, Virtual Vinyl, Cue or AtomixMP3.
VirtualDJ Forum
PC Version Technical...
timecode, no...
Autor - Topic: timecode, no signal, please help -
dienz
No license user
Posted Fri 26 Sep 08 @ 10:01 am
i have a virtual dj time code and virtual dj software, im using windows xp with a emu 1820m soundsystem, i got everything connected as they should be and my computer pick up the sound from the turntable, but it wont work in virtual dj, just no signal at all and looks like this:
[img=http://img151.imageshack.us/img151/8490/unavngivet3sf6.th.jpg][img=http://img151.imageshack.us/images/thpix.gif]
please i really tryed all i could think off and i dont know whats wrong?
dienz
No license user
Posted Fri 26 Sep 08 @ 10:02 am
VanStino
Experienced pro user
VDJ Radio DJ
Posted Sat 27 Sep 08 @ 4:27 am
Try to disable Clear Sound and enable RIAA Preamp. If that doesn't work, give another screenshot :)
jimmy b
VIP Member
Posted Sat 27 Sep 08 @ 4:34 am
Uncheck "Invert phase" and try lowering the gain.
acdj0712
Limited edition user
Posted Fri 10 Oct 08 @ 5:46 pm
I'm trying to hook up my Computer to my Mixer and Cd player. I use Velocity as Cd players and VDJ-pro +Hercules MK as a sound card. I downloaded the free Time coded Cd's i conected everything but i can't get it to work. It sounds like it's playing but at a slow speed.
Can you guys help out, am I missing something?
spinnaJ
Moderator
(mac beta tester)
Posted Fri 10 Oct 08 @ 10:14 pm
Download the consumer level tccd not the pro tccd in ur case. And make sure the it is select on line not phono at the back of ur herc;)
(C)opyright Atomix Productions 2009
VirtualDJ Pro
VDJ HomeEdition
DJC Edition
Trial Version
Sound Effekte
Video Effekte
Tools & Drivers
Users Network
Wiki
Atomix Productions
Disclaimer
Wiki
