me toys teleytaioys driver pou ebgale i hercules gia tin mk2,tis alazei kai to firmware tis konsolas mesa?to kserei kaneis ayto?
geposted Tue 07 Oct 08 @ 3:31 pm
Changes :
-Added support for DJ Control Steel.
-Upgraded KMDF coinstaller to 1.7 from 1.5- should fix some install issues.
-Fixed possible ASIO dropout issues when connected to a hub on Windows Vista.
- New DJ Console Mk2 firmware (v14) which solves a minor mixer issue.
-Minor bugfixes.
logika nai opos leei. to exo kanei ego alla de thymamai poia ekdosi eixe prin....
-Minor bugfixes.
geposted Tue 07 Oct 08 @ 4:04 pm
a wraia!!!!tin patisame gia ta kala twra!moliw to ekana egkatastasi kai pataga to koympi toy mikrofwnoy gia na doylepsw mikrofwno...krasare olo to sistima kai xreiazotan epanekinisi to virtual dj....to ebgala kai to ebala panw apo 15 fores kai pali ta idia...ekana to idio kai sto programma...mia apo ta idia...to exw balei se 3 laptop...kanei akribws ta idia...krasarei to sistima me to pou pataw to koympaki tou mikkrwfonou apo tin konsola........eleos!!egina rezili se party gmt!paw na ksanabalw ti palia ekdosi pou eixa 5.06 kai ton palio ton palio ton driver..kai distixws den ginetai tipota pleon..gia ayto psiliastika oti eixame kai allagi firmware.
kai ti kanoyme twra?to exei dokimasei kaneis allos to neo driver?
moy fainetai doyleia den eixame douleia anoiksame...
geposted Tue 07 Oct 08 @ 5:42 pm
kane auta kai bale to palio firmware. to eixa kanei ego auto otan eixan bgei oi 2007 kai ksanaebala tous 2006... tote..
oso gia to mikrofono kai mena to idio kanei! molis to patao kolaei to vdj! xaxaxaxaxaxa
Here is what you need to do if your controller dies (controller part, and not the soundcard) :
1) Kill the HDJ2CPL.exe in taskmanager.
2) Click Start, Run and type in "c:/Program Files/HerculesAudioDJ
Console Series/Mk2updater/hdj2updater.exe" -manual and click OK. (slashes other way, but the forum don't allow them). This opens up a flash tool for the firmware on the console.
3) Hold effect button 1 + 2 + 3 at the LEFT deck pressed down at the same time, and KEEP them pressed while you reconnect the usb cord to the console.
4) The firmware flash window should show "boot" for firmware controller if sucsessfull.
5) Press the Ctrl button at lower end, and choose the file "HDJ_PSOC1.djc"
6) Make sure there is a check mark in the Flash for the Firmware controller and press update!
if the Sound Section Fails
1- Disconnect the Console.
2- Shutdown the system. (Restart will not do, make sure to completely
shut it down)
3- Turn it back on.
4- Once completely restarted, close the MK2 mixer on the taskbar. If it
isn't there click Start, Run, type in taskmgr then click ok. Go on the
Processes tab and locate the HDJ2CPL.exe right-click it and choose end
process then click Yes on the warning message.
5- Click Start, Run and type in "c:Program FilesHerculesAudioDJ
Console SeriesMk2updaterhdj2updater.exe" -manual and click OK.
6- Hold talkover button on the console and reconnect it (make sure to
hold the button while plugging it back)
7- Now the DJ Console Mk2 Updater Firmware Controller should say boot.
Click the Open Ctrl... button and select HDJ_TUSB.dja file then click
Open..
8- Make sure there is a check mark in the Flash for the Firmware
9- Unplug the DJ Console and plug it back.
10- Check in the DJ Console Updater if a firmware is now installed.
11- Go in the Control Panel and then into Game controllers.
12- Go into the DJ Console Mk2 properties and move the treble knob on
the right side of the console. If it works your good to go, if it
doesn't repeat the procedure from section 7.
shut it down)
3- Turn it back on.
Open..
geposted Wed 08 Oct 08 @ 1:48 am
aaaaaaa brika kai lysi giati to kanei auto re.
mesa sto control panel tis hercules prepei na to baleis na douleuei se WDM mode!
etsi otan pas to koumpi tou mikrofonou, xamilonei ligo ti mousiki kai akougetai to mikrofono....
geposted Wed 08 Oct 08 @ 2:02 am
re seis,se wdm mode to exw ,kai to talkover to exv sta -6 db....dokimasa na to apenergopiisw kai pali kanei ta idia...kala re seiw aytoi otan bgaoyn kainoyrgio kati,to bgazoyn xeirotero?
geposted Wed 08 Oct 08 @ 4:04 am
se mena douleuei.....
ti exeis? xp i vista?
ego xp
ego xp
geposted Wed 08 Oct 08 @ 12:00 pm
vista....alla apo oti eipes prin kai esy exei to idio provlima e?
geposted Wed 08 Oct 08 @ 12:49 pm
nai otan pataga to koumpi gia to mikrofono kolage to vdj.
omos otan to allaksa se wdm meta de kolise.
itan se asio mode, de to eixa balei ego isos mpike mono tou meta to update.
dokimase na to baleis se asio mode kai meta ksana se wdm mpas kai to katalabei.
mesa apo to vdj epelekse san karta ixou ti mk2. diladi to eikonidio me ti mk2.
geposted Wed 08 Oct 08 @ 12:58 pm
to dokimasa kai ayto pou eipes den ginetai tipota!re sy sou lew to exw balei se 3 ypologistes me vista to kanei kai stou treis!den eksigite alliws,ftaine oi drivers!ti kanoyme twra?kana allos tin gnwmi tou?
geposted Wed 08 Oct 08 @ 4:10 pm
dokimase to kai se pc me xp...
geposted Wed 08 Oct 08 @ 4:53 pm
kala ayto einai anikousto!driver 10-08 na min paizei se vista....an kai den to dokimasa kai oyte tha to dokimasw...ti tha pei ayto,na min trexei se vista !!aman pia!olo asimvatotites akoma kai meta apo 2 xronia pou einai stin kikloforia ta vista..eleos!
geposted Wed 08 Oct 08 @ 6:41 pm
Den kserw poia ekdosi xrisimopoieis, alla dokimase na katebaseis tin teleutaia se demo apo to site. Yparxoun bug fixes gia tin MK2 stis teleutaies versions.
geposted Thu 09 Oct 08 @ 10:46 am
xrisimopoiw tin 5.2 pro kai tous teleyaious drivers gia tin mk2...
geposted Sat 11 Oct 08 @ 7:39 am
mia voithia re paidia.ekana format to pc,kai molis piga na kano egatastasi ksana to hercules mk2,to cd me toys drivers einai kleidomeno.yparxei kanena site gia na tous ksana kano egatastasi?na einai aksiopisto!!!!thanks
geposted Thu 26 Mar 09 @ 1:28 pm
Hello...provlima!
Katevasa ta drivers tou Hercules Mk2 gia Vista,ta egatestisa kai molis kanw klik na anoixw to Virtual(3.4.1) mou vgazei ''DirectX Error''
Ti mporei na simvainei?
geposted Fri 27 Mar 09 @ 12:12 pm
bale ti konsola se WDM mode apo to control panel tis.
allios dokimase na baleis to directX
enoeite oti mesa apo to vdj tha exeis epileksei ti hercules san karta ixou
geposted Fri 27 Mar 09 @ 1:09 pm
http://ts.hercules.com/eng/index.php?pg=view_files&gid=2&fid=28&pid=177&cid=1
apo do einai oi drivers
geposted Fri 27 Mar 09 @ 2:01 pm
Χαιρετε.Εχω το Hercules ΜΚ2 σε φορητο υπολογιστη με Vista.Δουλευε μια χαρα εως οτου του εβαλα τον οδηγο του 2009.Απο την στιγμη αυτη, καθως παιζω τα διαφορα κομματια ακουγεται ενας θορυβος κατα την διαρκεια τους ,αρκετα εκνευριστικος.Τον απεγκατεστησα αλλα το προβλημα εξακολουθει.Υπαρχει καμμια ιδεα επι αυτου μια και δεν ειμαι ιδιατερα σχετικος με το ζητημα ?
geposted Fri 29 May 09 @ 3:00 pm
