Forum: PC Version Technical Support - Topic: Problem Vrtual DJ 5.2.1 Dj Consol RMX
Ask here any technical questions about the functionalities of Virtual DJ, Virtual Vinyl, Cue or AtomixMP3.
VirtualDJ Forum
PC Version Technical...
Problem Vrtual...
Autor - Topic: Problem Vrtual DJ 5.2.1 Dj Consol RMX -
rezafeili
Limited edition user
Posted Wed 08 Oct 08 @ 5:09 am
Dear,
I recently bought the Hercules DJ Console RMX with Virtual DJ 5.2.1 DJ console, but unfortunately I have this huge problem. It usually takes 4-5min to load a song…a problem I didn’t have with the old virtual DJ. It took the older version just seconds to load up a song.
PC specifications:
Interl Celeron D
3GHz
1GB RAM
I’m looking forward to hear from someone really soon.
Kindest regards,
Reza
spinnaJ
Moderator
(mac beta tester)
Posted Wed 08 Oct 08 @ 5:24 am
Hi, is there reset to factory setting on the info tab in the config? If so click that. Also what format are those?
Regards;)
rezafeili
Posted Wed 08 Oct 08 @ 6:39 am
I reset the settings but the loading is still too slow. The songs that I'm trying to load are usually betweeen 3 - 4MB
spinnaJ
Moderator
(mac beta tester)
Posted Wed 08 Oct 08 @ 10:26 am
Have u updated to their recent driver?
There not much i can help regarding the limited version which have limited option. U may reinstalled the software and see if that help. Or u may go to the herc forum and ask there too. Sorry:(
I'm sure user using the rmx will assist u shortly;)
jimmy b
VIP Member
Posted Wed 08 Oct 08 @ 10:34 am
@rezafeili, your slow loading problem
How often do you do a disk-cleanup and defrag? Have you done one recently?
If not, then I would do both.
Also what file type are you trying to load.
dbthegroovemaster
Posted Mon 13 Oct 08 @ 3:08 pm
I am running Windows Vista on an HP pavilion DV5 laptop and I am having problems with thee Hercules RMX and Virtual DJ5. I constantly get an error message "Error in ASIO sound driver. I have un-installed and re-installed the RMX drivers also the birtual dj but the problem is the same. I have even switched the USB ports in case that was the problem but still not solved. after the error message the software will continue to load if the message is cancelled but when a song is selected it will not output, can someone please help.
TerranceG
Posted Wed 15 Oct 08 @ 8:04 am
geefuss
Posted Sat 25 Oct 08 @ 9:33 pm
HI I JUST GOT MY HERCULES RMX BUT FOR SOME REASON UNLIKE THE MK2 I CANT SEEM TO FIND OUT HOW TO LOAD UP MY SOUND EFFECTS CAN SOMEONE ASSITS ME IN DOING THIS
musicmac
Professional edition user
Posted Mon 08 Dec 08 @ 7:02 pm
Make sure your database is not corrupt...go into config/Browser and run Check/Clean/Fix.
You can get information on hoe to program the RMX from the Hercules Web Site http://ts.hercules.com/eng/index.php?pg=view_files&gid=2&fid=28&pid=215&cid=6
(C)opyright Atomix Productions 2009
VirtualDJ Pro
VDJ HomeEdition
DJC Edition
Trial Version
Sound Effekte
Video Effekte
Tools & Drivers
Users Network
Wiki
Atomix Productions
Disclaimer
Wiki
