| Autor | - Topic: how to connect ??? - |
Hi guys... how i can connect my laptop (which have instaled virtual dj) with mixer??? I mean which cable i should use for this??? thanks a lot... |
If you are using a mixer you need an external sound card. Like the M-Audio Conectiv, Maya, etc. http://www.zzounds.com/item--MDOCONECTIV |
it's best to have an external sound card, if however you don't just now you may want to try this... basically if you cant follow the clip go to config soundsetup outputs > external mixer soundcards > mono seperated output channels give you white lead/left channel red lead/right channel to your mixer you will have to use a y splitter for each channel to get dual inputs into mixing desk which of course will only give you mono sound output |
