| Autor |
- Topic: Virtual DJ - Behringer BCD-2000 software crash problem - |
Posted Mon 13 Oct 08 @ 5:34 am
Dear all,
i have a bcd-2000 which i use with Virtual DJ. everytime i start to play/record a set , after several minutes , music stops and none of the bcd-2000 buttons/jogs responds, and when i try to close the virtual dj, it says "music is still playing, are you sure?" , but music is not playing. i tried everything. i changed every sound setup. i thought it's because i also use m-audio firewire 410 plugged via firewire to my laptop. but even if i disconnect maudio fw410, bcd-2000 alone still crashes. i have 512 mb 1.7 ghz laptop which i believe not the best but can afford virtual dj's system requirements. please help. because with this problem bcd and virtual dj is useless to me. i can't even play a 1 hour set. thanks
Posted Mon 13 Oct 08 @ 11:43 am
Dear all,
By chance are you using the asio mode and default soundcard of the bcd2000?If so change the soundcard to the asio of the m-audio soundcard because the bcd2000 has a bad chipset within it causing weird results.The midi implementation is almost perfect but the soundcard is waste of time.
