Forum: Music discussion
Topic: Microphone broadcasting problem with RMX and VDJ
Hi there
Apologies if this has been answered a number of time. I tried logging a support question and got told to post here.
here is the problem
i use virtual dj with my new rmx mk2 but when i broadcast i cant seem to get the mic to broadcast, it sounds like its working out of the system but not broadcasting. Can you lend a hand please?
Everytime i set the mic to hercules when i click broadcast it says no sound detected and I can use the soundcard on my pc and it needs to come from hercules. Can anyone advise how to overcome this?
thanks
Sean
geposted Mon 20 Oct 08 @ 9:03 pm
In the Config tab above broadcasting make sure your sound card is Master + Mic and make sure the MK2 is selected as primary sound card.
geposted Tue 23 Dec 08 @ 11:54 am
louraHome userMember since 2009
Thanxxxxxxxxxxxxxxx
geposted Fri 20 Mar 09 @ 10:55 pm
but, how to use it?? n how to mute mic when the song was playing??
or just like push to talk..wht i must to do??any one know??
geposted Thu 11 Jun 09 @ 5:02 am
Haui70PRO InfinitySenior staffMember since 2008
There are many ways: :-)
-Use the linefaders to mute the songs
-Use the plugin for users in the download area
or
-Use a mixer with a talk over function
geposted Thu 11 Jun 09 @ 5:14 am
coach kPRO InfinityMember since 2010
Does this apply for the Macbook pro as well?
geposted Mon 20 Dec 10 @ 6:42 pm
Heres the script I use for a talkover switch,
"master_volume 50% while_pressed & deck 4 linein mic on & down ? deck 4 linein mic on : deck 4 linein mic off"
For this to work you must assign the mic to a deck with a shortcut like this,
go into mappers pick "M" and then type in "deck 4 linein mic"
Hope this helps
Huey
geposted Tue 21 Dec 10 @ 12:04 am
Config --> Mappers --> make a mapping to whatever "Key" you want (I use "M") then map it to the "Action" "mic"
geposted Sat 11 May 13 @ 9:20 pm
udo12Home userMember since 2014
Wo finde ich bei Virtual DJ Broadcast Push to Talk
geposted Sat 29 Mar 14 @ 2:33 pm
Sorry, this forum is for English language messages only.
Please either post your message again in English or use the correct language forum: http://www.virtualdj.com/forums/6/German_Forum.html
NOTE: This forum is for discussion about VirtualDJ Radio only. For software/hardware technical support, please use the appropriate forums.
geposted Sun 30 Mar 14 @ 11:36 am
"Config tab above broadcasting make sure your sound card is Master + Mic"
I cannot find this function
geposted Mon 06 Mar 17 @ 1:24 am
The text you quoted was written in 2008, so it refers to VDJ 7. Presumably you are using VDJ 8.
geposted Mon 06 Mar 17 @ 6:21 pm
