| Autor | - Topic: Senior thesis needs help! - |
Howdy all, I am working on my senior thesis and it has to do with a new type of controller for DJing! I chose to use virtual dj because of the custom plug ins and various skins, but because I only have the demo version this site won't let me get to them. I know the obvious thing to do is go out and spend the $200 and get a serial but I don't have that kind of money to spend, so I figured I would come to you guys and ask if you would be willing to send me a plugin now and a gain for this project I would really appriciate it! You will be get credit for helping and I will send you a copy of the final thesis if you want. I just really need some help! Thanks, Alex |
Sorry, you must purchase VirtualDJ to gain access to downloading plugins and other add-ons: http://www.virtualdj.com/buy/index.html Please DO NOT ask our registered licensed users to send you plugins. This will not happen. If you have programming skills, you can create your own plugins using the SDK: http://www.virtualdj.com/wiki/Plugin_Guide.html |
If you're creating a controller, it will need to be MIDI to work, so you won't need access to any plugins anyway :) |
Yup, all you need is to know the midi protocol, and you can program it for this software. http://www.gweep.net/~prefect/eng/reference/protocol/midispec.html Unless you'd want a full native support, but than you'd need to get in contact with the company anyway... |
