DJ_Gauge
Tue 01 Aug 06 @ 3:32 am
finally got my turntables
Thu 27 Jul 06 @ 2:34 am
here is the final product. gloss black base iwth flat black tribal graphics
Mon 19 Dec 05 @ 11:05 am
ok seems like apparently i'm the goto guy for mouse scratching now... lol
Here is what i do...
find you a good sample to scratch, like an accapella or "aaahhhhh sample or that was fresh" etc.
put a nice simple beat on one deck for starters. Load the track your gonna scratch on other deck. set up keyboard shortcut for crossfader value = 2048 and click the temporary checkbox. now set your crossfader curve to full
then start playing your beat and put crossfader all the way to the side that the beat is playing on.
now click on record and drag too scratch, use the keyboard shortcut you made to center the crossfader, so you will only hear the scratching when the button is pressed. basically you can cut in and out by tapping on the keyboard button...
the actually scratching just takes lots of practice.
also i setup a shortcut to drop the level fader of the beat deck to zero on temporary as well so i can drop the beat out during a scratch and then bring it back...
practice practice practice
upload them then let me listen i will do what i can to help out...
-gauge
aka mouse-bert
lol
Sat 12 Nov 05 @ 6:09 pm
new setup woo hoo got some hardware now!!
ok here is how i have my setup mapped
i use DJ Cels hercules mk2 mapper
level sliders = pitch
pitch knob = gain
eq knobs on both channels = sample volumes and they are set to autoplay
everything else is normal
