Deun-Deun
What could be the incredible Pioneer's mixtables like DJM2000 without their awesome effects ? I can not imagine.
What could be the best DJ software in the world, I mean VDJ of course, with such effects as Pioneer ones ? Here, I can imagine !
I'll try to achive this target by developping audio plugins : easy to use for a maximum of effects...
"To infinity, and beyond" (Buzz Lightyear)
Find demo of some of my last FX in my blog dedicated below.
Structured as the amazing Pioneer EFX 500 with :
- 6 ratio BPM button : 1/4 1/2 3/4 1/1 2/1 4/1 (only if beat FX)
- 1 slider : Mix Dry/Wet or Depth
Easy to use for a maximum of efficiency !
Uploaded in October 2011
Sound Cutting :
- Gate
- Trans
Delay :
- Delay
- 3P Delay (Ping Pong Delay)
Loop :
- Roll
- Slip Roll
Uploaded in November 2011
Sound Processor :
- White Noise
Beat FX :
- Rev Roll
- Pitch Echo
- Multitap Delay
- Echo
- BeatMasher single
Uploaded in December 2011
Sound Processor :
- Fader Synthe
Beat FX :
- Beatmasher Group
Uploaded in January 2012
- Beatslicer : put the track in a pinball machine
- Ramp Delay : it creates like an elastic echo
- Gate Echo
- Sidechain Remix : add kick, drums,... any sample sync to the pulse of track automatically
- Water bubbles : Let mermaids dance
- EFX1000 Delay : Echo with Frequency Mix
Uploaded in April 2012
Laser Ray : Make space women's heart melt
DJM700 Roll : Roll FX in association with manual Low Pass Filter / High Pass Filter. In double mode, the filter is applied to roll and track as well
DJM850 Filter : Low Pass Filter / High Pass Filter in association with a sidechain compressor
Magic Gate : Gate combined with a Frequency mix and optionnal overloop (DJM850 Gate)
White Noise v2 : white noise with optional sidechain compressor (DJM 850 White noise)
Touch phaser : phaser linked to the sound level of track and until 32 stages
E-Drum : enable to add Hi Hat, Clap, Snare or Kick trigger by a sidechain
Uploaded in May 2012
White Noise v3 : white noise (new algorithm) with optional sidechain compressor (DJM 850 White noise)
Black & White Noise : white noise with transform FX
Next uploads (if I won't forget....)
- Loopslicer : juggle the 8 beats of loop
- SlicerRandom : Loopslicer randomized
Mon 02 Jan 12 @ 1:54 pm
3 FX From Pioneer DJM2000 :
- Roll : you can dowload here > http://www.virtualdj.com/addons/13750/ROLL.html
- Slip roll : you can dowload here > http://www.virtualdj.com/addons/13751/SLIP_ROLL.html
- Sidechain sampler (not yet available)
2 FX From Pioneer EFX1000 : (not yet available)
- Roll Multitap
- Feedback Looping
Mon 02 Jan 12 @ 12:33 pm
Vinyls Remix >
Sun 03 Jul 11 @ 4:30 pm
Have an overview of FX to come soon. If already available, version and date
Of course, this is not the final list :-)
3P (Pingpong) delay : v1--> 2011 10
Delay : v1 --> 2011 10
Gate : v1 --> 2011 10
MultiTap delay : v1--> 2011 11
Pitch Echo : v1--> 2011 11
Reverse Roll : v1--> 2011 11
Roll : v1 --> 2011 10
Slip Roll : v1 --> 2011 10
Transform : v1 --> 2011 10
White Noise : v1--> 2011 11
Jet
Phaser
Flanger
Flanger Pan
Reverse Delay
Pan
Echo
Ducking Echo
Slip Echo
Echo MultiTap
Feedback Loop
Up Roll
Down Roll
Roll Multitap
Transform Multitap
Synthetisor
Side Chain
Groove box by triggering VDJ samplers
New shakerbeat with 4 multitaps
Some scratch FX : Cue A and Forward
Wed 19 Dec 07 @ 2:33 pm
English : Shorcuts are requested to use this plugin. Here the value you have to define to change the rythm by press key F1 (as 1/8 beat) to F8 (as 8/1 beats).
F4 correspond to 3/4 beat.
Français : voici les raccourcis à créer pour utiliser le plugin. Pour ma part, j'utilise les touches F1 à F8, qui couvrent le 1/8 de beat jusqu'à 8/1 beat. La touche F4 correspond au rythm 3/4.
<sc key="f1" action="effect_slider_1" value="256" />
<sc key="f2" action="effect_slider_1" value="768" />
<sc key="f3" action="effect_slider_1" value="1280" />
<sc key="f4" action="effect_slider_1" value="1800" />
<sc key="f5" action="effect_slider_1" value="2048" />
<sc key="f6" action="effect_slider_1" value="2560" />
<sc key="f7" action="effect_slider_1" value="3072" />
<sc key="f8" action="effect_slider_1" value="3584" />
See demo on YouTube --> http://www.youtube.com/watch?v=URpQkXbL83E
Thu 08 Nov 07 @ 10:42 pm
On the picture, it's me with white clothe. The other one, it is a bear :-)
Sat 10 Sep 05 @ 8:07 pm
Parameters:
Option for Insert:
Button 0 = Sound Dry: On (rythm over the song) / Off (rythm only) / Trans (cut rythmed)
Slider 0 = Level Wet : Level of wet sound (only if "Sound Dry=Off")
Beat used for the rythm:
Button 1 = Tape : On (beat changes every N beats, according to slider 1) / Off (beat changes every BPM)
Slider 1 = BPM Tape : choose when you want to change the beat used for rythm, from 1 to 8
Pan:
Button 2 = Pan : Off (not actived), Rythm (pan synchronised with rythm), BPM (pan synchronised with a number of BPM, according to Slider 2)
Slider 2 = BPM Pan : define how many BPM you want to change channel for pan
LFO:
Bouton 3 = LFO : Off, On
Slider 2 = LFO : define how many BPM you want to synchronise LFO level volume of effect
Rythms
Invisible Buttons : (you have to use shortcuts). You can see the various rythms on following picture
shortcuts and rythms linked
raccourcis 10: 1 crotchet
raccourcis 11: 2 quavers
raccourcis 12: 4 semiquavers
raccourcis 13: 8 triplequavers
raccourcis 14: 1 quaver + 2 semiquavers
raccourcis 15: 1 semiquaver + 1 quaver + 1 semiquaver
raccourcis 16: 2 semiquavers + 1 quaver
raccourcis 17: 1 quaver with point + 1 semiquaver
raccourcis 18: ROLL (rythms synchronised with crossfader position)
raccourcis 19: 1 semiquaver + 1 quaver with point
raccourcis 20: 1 quaver with point + 1 semiquevar + 1 quaver (Ternar)
raccourcis 21: 6 semiquavers (Ternar)
Scheme of rythms synchronised with crossfader position (ROLL)
Thu 11 Aug 05 @ 2:51 pm
Paramètrages
Insertion de l'effet:
Bouton 0 = Sound Dry: On (rythmique ajoutée à la chanson) / Off (rythmique pure) / Trans (Cut en rythme)
Slider 0 = Level Wet : Niveau de l'effet de 0 à 100 (désactivé si Sound Dry=Off)
Beat de base pour la rythmique:
Bouton 1 = Tape : On (le beat de base change tous les N beats, suivant slider 1) / Off (changement de beat à chaque bpm)
Slider 1 = BPM Tape : le beat de base change tous les N beats, de 1 à 8
Panoramique:
Bouton 2 = Pan : Off (pas de panoramique), Rythm (panoramique câlé sur le rythme), BPM (panoramique câlé sur un multiple du BPM, paramétré par le Slider 2)
Slider 2 = BPM Pan : Multiple de BPM pour l'effet panoramique
LFO:
Slider 2 = LFO : Multiple de BPM pour le cycle du volume de l'effet
Rythmique
Boutons non apparents: (accès obligatoire par raccourcis clavier, à l'idéal touches du pavé numérique étiquettées). Voici par exemple ce que cela donne sur mon pavé numérique
Touches de raccourcis et rythme activé
raccourcis 10: 1 noire
raccourcis 11: 2 croches (triolet/ternaire)
raccourcis 12: 4 doubles
raccourcis 13: 8 triples
raccourcis 14: 1 croche + 2 doubles
raccourcis 15: 1 double + 1 croche + 1 double
raccourcis 16: 2 doubles + 1 croche
raccourcis 17: 1 croche pointée + 1 double
raccourcis 18: Rythmes synchronisés sur crossfader
raccourcis 19: 1 double + 1 croche pointée
raccourcis 20: 3 croches (triolet / Ternaire)
raccourcis 21: 1 croche pointée + 1 double + 1 croche (sicilienne / Ternaire))
raccourcis 22: 6 doubles croches (sextollet / Ternaire)
Schéma des rythmes synchronisés sur crossfader (effet ROLL)
Fri 05 Aug 05 @ 9:59 am
Effet panoramique à 4 bandes
BOUTONS
bouton 1 à 4:
Hi : High (bouton 1)
MidHi : haut médium (bouton 2)
MidLo : bas médium (bouton 3)
Low : Bass (bouton 4)
Pour chaque bouton: 4 options dont 2 niveaux de panoramique.
On = son sur les 2 enceintes (son normal)
Pan = effet panoramique
i-Pan = effet panoramique en opposition à Pan. (exemple: quand Pan à gauche, i-Pan à droite)
Kill = suppression de la bande de fréquence
bouton 5 : liaison avec le crossfader de VDJ ou non :On / Off
L'effet panoramique s'accélère de 1 à 8 fois en fonction du glissement du crossfader vers le titre prochain
SLIDERS
La lecture des valeurs se lit sur les étiquettes des sliders
Slider 1 : LFO avec les valeurs 1, 2 et 4
Slider 2 à 4 : on régle la fréquence de coupure des bandes de fréquences
MidHi : CutHmid (mini: 4000 hz / maxi: 12000hz)
MidLo : CutLmid (mini: 250 hz / maxi: 4000hz)
Low: CutLow (mini: 0 hz / maxi: 250hz)
Slider 5 : on règle le son minimum sur les 2 canaux (paramètre classique qui permet de doser l'effet panoramique)
Wed 15 Jun 05 @ 10:00 pm
Un flanger avec un LFO qui permet de contrôler la durée d'un aller/retour de l'effet flanger.
Le LFO est en nombre de beats. Autrement dit l'effet est câlé sur le bpm et commence à partir sur le premier cbg suivant l'enclenchement
Un effet de looping est intégré, à l'image du boomerang, donnant une touche supplémentaire au flanger. Ce looping est lui aussi branché sur la durée LFO.
Bouton 1: LFO en nombre de beats
Slider 1: délai réglable avec un maxi à 20 ms. (pour des basses hyper graves)
Slider 2: volume ou résonnance du flanger.
Fri 10 Jun 05 @ 10:19 am
Bouton 1: en entrée, choix du ou des canaux à retransmettre aux enceintes
.................Enceinte Gauche...........Enceinte Droite
stereo..........Canal gauche................Canal Droit
mono left......Canal gauche................Canal gauche
mono right.....Canal Droit...................Canal Droit
mono............Canaux Gauche+Droit.....Canaux Gauche+Droit
Slider 1: Niveau de sortie de l'enceinte gauche
Slider 2: Niveau de sortie de l'enceinte droite
Thu 09 Jun 05 @ 10:33 am
When you launch a boomerang, it goes away (stage 1) and comes back automatically (stage 2)
That's you can do with the sound of a sample with this plug.
As the stages have separeted parameters , you can create 2 stages from identical strictly to inversed completely.
Here some explanations for parameters:
First define the sample:
botton 1 = insert
break : only wet sound (the sample). The plug stops automatically and the song starts again where you launched the boomerang effet.
overloop : the boomerang plays over the sound dry. you have to stop it manually
slider 1: lenght of the sample in beats
Secondly: You manage the stage 1
botton 2 : the sample can be played normally or with reverse mode
botton 3: the ouput is normal, pan in phase with bpm, channel right only or channel left only
slider 2: choose a rythm (like shaker beat) for the sample if you want
silder 3: choose how many time you want to listen to the sample
Thirdly = you manage the stage 2
botton 4 = botton 2
botton 5= bouton 3
slider 4 = slider 2
slider 5 = slider 3
And now, test it "to infinity, and beyond" :)
Mon 06 Jun 05 @ 9:43 pm
L'idée de ce plug est de traiter un échantillon qu'on diffuse d'après le modèle du boomerang
On lance l'échantillon, il disparait progressivement (phase down) et revient (phase up) : d'où boomerang
10 paramètres dont 2 pour l'échantillon:
bouton 1 = type d'insertion
soit break : on ne diffuse que l'effet avec arrêt programmé. La chanson reprend là où on a inséré l'effet. soit overloop : l'effet boucle sans s'arrêter en toile de fond sur la chanson
slider 1: longueur de l'échantillon en beats
Le paramètrage des 2 phases est le même mais se fait de manière complétement indépendante.
On peut donc programmer 2 parties complétement symétriques, symétriques inversées ou asymétriques.
On a donc 4 paramétres identiques pour chaque phase pilotées par les 8 paramétres restants. Vous suivez ... :)
Pendant toute la descente du son
bouton 2 : l'échantillon est lu normalement ou en mode reverse
bouton 3: stéréo, panoramique, enceinte droite seule ou enceinte gauche seule
slider 2: choix d'un rythme (idem à shaker beat) sur l'échantillon
silder 3: nombre de fois que l'on répète l'échantillon
Pour le retour du son les mêmes réglages sur les paramètres :
bouton 4 = bouton 2
bouton 5= bouton 3
slider 4 = slider 2
slider 5 = slider 3
Wed 18 May 05 @ 9:35 pm
Here, I explain what you can do with Shaker Beat V1.1 effect, my very first plugin.
I tried to do something close to "beatbraker".
You allow to manage a sample of 4 beats maximum. As soon as the effect is off, the initial song goes on 4 beats from where you launched the plugin.
You can select each beat you want to listen to with bottons 2 to 5.
You can add new rythm for each beat selected with slider 2 to 5.
You can choice how many beats you want to affect in the plugin (1 to 4) with botton 1 or slider 1
As soon as you launch the plugin, the effect takes into account the 4 beats following but from the first next CBG.
Parameters :
botton 1: you can select 4 effects
- "Normal" = after shakerbeats, go back when you launched the plugin
- "Over pan" = you add on the initial song the shakerbeats with pan mode
- "Go on": after shakerbeats, the song goes on without starting where you launched the plugin
- "Reverse": same as "Normal", but with reverse mode
botton 2: the number of beat from the initial song you want to listen to on beat 1 with effect
botton 3: the number of beat from the initial song you want to listen to on beat 2 with effect
botton 4: the number of beat from the initial song you want to listen to on beat 3 with effect
botton 5: the number of beat from the initial song you want to listen to on beat 4 with effect
slider 1: number of beats you want to manage (the same as botton 1 in V1.1)
slider 2: rythm on beat 1 selected
slider 3: rythm on beat 2 selected
slider 4: rythm on beat 3 selected
slider 5: rythm on beat 4 selected
Find the detail of the rythms you can preset with slides 2 to 5, from top to down :
1000 = 1 crotchet (initial rythm)
1010 = 2 quavers
1111 = 4 semiquavers
1001 = 1 quaver with point + 1 semiquaver
1100 = 1 semiquaver + 1 quaver with point
1011 = 1 quaver + 2 semiquavers
1110 = 2 semiquavers + 1 quaver
1101 = 1 semiquaver + 1 quaver + 1 semiquaver
At the bottom of the plugin, you can see that the line which indicates the parameter mixes on the one hand the beat selected and on the other hand the rythm.
That's why you can see 3030 if you choose the beat 3 and the rythm "2 quavers" for this beat (instead of 1010).
I would like to thank DJCEL, who takes so many times to explain to me the C langage and the structure of a plugin, and CLAX who helped me to manage the sound through a plugin and made the picture of my plugin.
If you find a bug or if you have any question, you can contact me by my email (see about me)
But right now, have fun !!!
Wed 11 May 05 @ 5:58 pm
Voici ce qu'est Shaker Beats V1.1, mon tout premier plugin, inspiré d'un appareil appelé beatbraker, le champion de la répétition.
Ici l'idée est d'avoir un échantillon de 4 beats maximum à piloter (voir ci-dessous)
Une fois l'échantillon trafiquoté terminé, le titre reprend 4 beats après que l'on ait lancé le plugin sans coupure ni décallage...
L'effet est une permutations des beats complétement paramétrable (boutons), et sur chaque beat on peut trafiquer la rythmique à volonté(sliders). La durée du plugin est également paramétrable: de 1 à 4 beats via soit le bouton 1, soit le silder 1.
L'effet porte sur les 4 beats qui suivent le lancement du plugin. Il prendra réellement effet sur le premier CBG suivant le lancement, autrement dit il est câlé au tempo.
Au niveau des paramètrages, il y a :
bouton 1: il permet de jouer sur la manière dont vous voulez insérer l'effet: 4 modes différents
"Normal": le titre initial reprend à partir de l'endroit où on a lancé le plugin
"Over Pan": ajout de l'effet en mode panoramique sur le titre initial
"Go on": le titre initial reprend là où l'effet s'arrête (Idem version V1.0)
"Reverse": le même que l'option "Normal" mais en mode reverse
bouton 2: numéro du beat de l'échantillon initial (1 à 4) à passer sur le temps 1
bouton 3: numéro du beat de l'échantillon initial (1 à 4) à passer sur le temps 2
bouton 4: numéro du beat de l'échantillon initial (1 à 4) à passer sur le temps 3
bouton 5: numéro du beat de l'échantillon initial (1 à 4) à passer sur le temps 4
slider 1: durée de l'effet en nombre de beats (idem au bouton 1 dans cette version V1.1)
slider 2: rythmique sur le temps 1
slider 3: rythmique sur le temps 2
slider 4: rythmique sur le temps 3
slider 5: rythmique sur le temps 4
Rythmiques possibles pour chaque beat dont voici le codage dans le plugin en partant de haut en bas par rapport à la position des silders 2 à 5 :
1000 = 1 noire (rythme original)
1010 = 2 croches
1111 = 4 doubles croches
1001 = 1 croche pointée + 1 double
1100 = 1 double + croche pointée
1011 = 1 croche + 2 doubles
1110 = 2 doubles + 1 croche
1101 = 1 double + 1 croche + 1 double
A noter: dans la ligne du bas qui restitue les paramétres sélectionnés, j'ai mélangé la sélection du beat avec la rytmique . C'est pourquoi en sélectionnant par exemple le beat 3, on aura 3030 si on a choisi le rythme "2 croches" associé au beat 3 (au lieu de 1010).
Pour mémoire:
démarrage du projet: mardi 10 mai 2005
fin du projet prévue au 27 mai .... 2005 aussi :)
fin du projet réel: 18 mai 2005
Un grand merci à DJCEL qui a passé de longues soirées à m'expliquer le langage C et m'a tout appris sur la structure des plugins et à CLAX qui m'a aidé à y voir clair dans la manipulation du son et a réalisé le graphisme de l'effet.
Si tu trouves un bug ou si tu as des questions par rapport au plugin, contacte moi par email (tu le trouveras dans la catégorie "about me"
Mais pour l'heure, bon amusement!!!
