General MIDI
Last edit by JeremK, Team on Sat 27 Jun 09 @ 10:54 am
General MIDI
For controllers which are not natively supported the general midi system is utilized bellow are some example controllers.
Visit Here for more information on mapping these Need to link
Wireless controllers
ITM DJ for iPhone
ITM DJ is a virtual MIDI controller. It can be used with VDJ.
English tutorial
Tutorial français
Table Top Controllers
Reloop Digital Jockey
The Digital Jockey by Reloop is dedicated to the future: It makes playing, mixing and manipulating music from a computer's hard disc as easy as using DJ CD-players and a mixing console. At the core, the Reloop Digital Jockey is a fully assignable MIDI controller that can send up to 69 MIDI parameters that are accessible via buttons, faders, encoders, push-rotaries, and two oversized high resolution jog wheels. The console scores with full-size DJ-friendly controls, a classic 2-channel layout, high quality faders and backlit control buttons. A huge Trax-encoder allows for the most intuitive browsing in music libraries. The Digital Jockey is easily connected and powered via USB, making it ideal for mobile use.
VESTAX VCI 100
The Vestax Vci is a high quality tabletop midi controler featuring touch sensitve jogs and high quality faders and crossfader. It can control all functions of VDJs internal mixer.
MIXERS
Behringer DDM 4000
- Console DJ Numérique 32 bits avec Sampleur Synchronisé au Rythme, 4 Sections d'Effets, 2 Compteurs de BPM Brevetés
- Crossfader Numérique et Implémentation MIDI
- 4 Canaux Phono/Ligne Stéréo pour Mixer jusqu'à 8 Sources Sonores Simultanées
- 2 Entrées Micro avec Gain Réglable, Egaliseur, Fonction Talk et Effets
- 4 Canaux Stéréo avec Gain réglable, Egaliseur paramétrique 3 bandes programmable avec fonction Kill
- Contrôle de la Courbe du Fader et Assignation polyvalente au Crossfader
- Sampleur avec fonction de Boucle asservie au rythme, contrôle du pitch en temps réel, effets et option Crossfader start
- 2 moteurs d'Effet de Haute Qualité asservis aux BPM et assignables librement (bitcrusher, resonator, reverb, flanger, etc.)
- Compteur de BPM breveté extrêmement rapide et précis pour la synchronisation automatique en MIDI du sampleur, des effets, du crossfader, de boîtes à rythme externes, etc.
- Crossfader numérique avec réglage de courbe, crossfading synchronisé aux BPM plus touches Reverse et Automatic
- Crossfader 2 modes avec nouveau croosfading sélectif en fréquences
- Section Casque avec fonctions PFL Mix/Split et Bass/Snare Boost
- Touche de rappel de la dernière configuration de la console
- Sortie S/PDIF numérique pour l'enregistrement direct de tes performances
- Composants de haute qualité et Fabrication exceptionnellement robuste pour des années de fiabilité
DJM-800
The DJM-800 is an advanced mixer that can act as both a real mixer and a MIDI mixer controlling VirtualDJ's own internal mixer.
Allowing all features of the software to be controlled direct from the mixer.
X-Session Pro
The X-Session Pro is the perfect MIDI mixer to drive VirtualDJ's own internal mixer.
This solution is particularly useful if you want to mix video, and need to control the video crossfader.
NU04 midi mixer
The NUO4 mixer from Ecler is a professional mixer that can control VirtualDJ directly, thanks to its MIDI commands. It is of great interest to DJs who mix video, since its crossfader will also control VirtualDJ's video crossfader.
This controller is a mixer in its own right which can sync with the software while you mix.
This revolutionary 4 channel mixer featuring control of external devices via MIDI, allows deejays to play software live in a natural and intuitive manner. This remote controller features 72 different MIDI messages, which can be fullyprogrammed to your choice and customized later on with an innovative label print system. The NUO4 concentrates to control of a computer in a traditional mixer and so allows laptops to coexist at deejay booths with turntables and CD decks, so bringing deejays an open window to the future of live music mixing and production...
Evolution UC33e
The perfect samples mixer.
The UC33e gives you a set of 9 faders that will reveal the true power of the new sample machine of Virtual DJ. All the knobs and buttons can also be assigned as midi shortcuts to drive any function you want in VirtualDJ.
So you can fire of samples at the touch of a button via setting autostart on a chosen sample.
Performance Pads
AKAI PROFESSIONAL MPD24
The Akai MPD24 is a velocity sensitive pad controller for musicians and DJs working with sampled sounds.
The Akai MPD24 features 16 MPC-style velocity and pressure sensitive pads plus transport controls for interfacing with DAW/sequencing applications. With Akai’s MPC 16 Levels and Full Level features for ultimate pad control, four selectable pad banks totaling 64 pads, six assignable faders and eight assignable, 360 degree knobs for transmitting MIDI Control Change data, the Akai MPD24 provides unprecedented creative freedom for manipulating sampled material.
Akai MPD24 main features include:
* 16 MPC-style velocity and pressure sensitive pads
* 4 selectable pad banks for a total of 64 pads
* 6 assignable Faders for transmitting MIDI Control Change data
* 8 assignable 360 degree knobs
* REW, FF, STOP PLAY and REC buttons that transmit MMC (MIDI Machine Control) messages to DAW/ Sequencing applications
It can be mapped to trigger samples and FX in Virtual DJ allowing fast access to these features.
AKAI PROFESSIONAL MPD32
The AKAI MPD32 is similar to the MPD24 with more faders , better knobs and note repeat functions.
MAUDIO TRIGGER FINGER
Trigger Finger puts the power to program and perform expressive percussion and drum parts at your fingertips. Its 16 velocity-sensitive pads are perfect for playing the drum sounds in your favorite software, launching loops and samples, or even controlling video projections—and applying pressure to the pads can generate any MIDI controller you wish.
Keyboard Controllers
AKAI PRO - MPK 49
The Akai MPK49 features MPC 'Full Level' and '12 Levels' functions on its pads, and MPC Swing can be applied to both Note Repeat and Arpeggio functions. Tap Tempo and time-division buttons allow for real-time control of Note Repeat and Arpeggio clock speeds. The Akai MPK49 delivers an amazing 76 assignable controls, with assignable inputs that include an expression pedal, footswitch, pitch bend and modulation wheel.
The MPK 49 can be mapped to control the FX and Sampler functions for quick acess to these features as well as any other functions desired by a user.
The Korg nanopad/keyboard/kontrol
These controllers are very appreciated in all german forum.
(C)opyright Atomix Productions 2009
VirtualDJ Pro
VirtualDJ Basic
VirtualDJ Home
Demo Version
Sound Effekte
Video Effekte
Wiki
Disclaimer
Wiki
