Plugin_Guide
Official Developer SDK (SDK v6) :
Click here
A wizard (based on SDK v4) is available that will create a basic plugin C++ project for you.
To build plugins in C++ with Microsoft Visual C++ 2003/2005/2008:
Download & Install the Wizard
How to build a plugin with Microsoft Visual C++:
  • Open Visual C++ or Visual Studio
  • "File" -> "New" -> "Project"
  • A new window appears
  • Select "Visual C++"
  • Select "VirtualDJ"
  • Click on "VirtualDJ Plugin"
  • Give a "Name" to the plugin (do not use spaces)
  • Define the "Location"
  • Click "OK"
  • Select the kind of plugin you want
  • Click on "Finish"
The wizard does not currently support MS VC++ 2010. You can still build plugins using 2010 obviously by using the raw SDK files.
To build plugins in C++ with Apple XCode :
Download
Wiki HOME
