I need to know how to control the filter knob found in the VDJ standard skin.
I will assign this to be controlled by the touchwheel (as I do with the other FX)
geposted Thu 26 Mar 15 @ 11:53 am
Using "filter"...?
Since the touchwheel outputs relativ values, you can tweak the speed by using something like "param_multiply 2 & filter".
Sorry if i don't get your question right :/
geposted Thu 26 Mar 15 @ 4:45 pm
i would like to learn from you how to assign filter knobs in standard skin to hc4500
geposted Thu 26 Mar 15 @ 6:58 pm
That function is not available to home users. You would have to upgrade to LE, Plus, or Pro Infinity.
geposted Thu 26 Mar 15 @ 8:24 pm
I don't think LE lets you remap.
geposted Thu 26 Mar 15 @ 11:23 pm
No home users can do all that.
geposted Fri 27 Mar 15 @ 1:29 am
The chart is correct, Home users can skin and map and script
the only thing that is out is the "interface with HW," which home can do but only for 10 minutes
geposted Fri 27 Mar 15 @ 2:11 am
I have mapped the jogwheel (or touchwheel) to control FX1 knob when I am in "Effect" mode.
This means I can change the effect parameter (FX1) as soon as I have an effect running (Flanger, Reverb....)
I also look for a way to change the knob named "Filter" - is this filterfunction treated as an effect in VDJ?
geposted Fri 27 Mar 15 @ 2:23 am
The filter on the skin works with the command
filter
It's there on the verbs page
filter
geposted Fri 27 Mar 15 @ 2:41 am
Thanx again! :)
geposted Fri 27 Mar 15 @ 3:00 am
XD
geposted Fri 27 Mar 15 @ 4:43 am
