PC / VDJ 8 Pro
Okay, this may be a stupid question, but how do I make the Video (Preview Window) smaller, it is taking up the whole laptop screen!
For instance: If I am DJing a gig with no video, no external screen hook up, audio only and accidentally load up a video track rather then an MP3, it takes up my entire screen and the only way to exit it is by using Control + Alt Delete and closing it out in the Task Manager.
If I click on the video preview pain inside virtual DJ, while running a video, that will also take up the entire laptop screen when running video to an external T.V. screen.
I cannot seem to find any video preview only settings in config. Any Help would be appreciated. Thanks!
geposted Mon 03 Aug 15 @ 10:10 pm
Just double click on the video and you should get the video window back, which you now can resize or close.
Alternativly, CTRL+V will close the video window.
geposted Tue 04 Aug 15 @ 7:39 am
The same issue is happing to me, and I click on the video and nothing happens.
I"d like to be able to choose what monitor the video is to be display, in other words drag the video
Thanks
Thanks
geposted Sat 25 Feb 17 @ 1:30 pm
