can someone help me for this error? what can i do? thanks!
geposted Fri 03 Mar 17 @ 7:26 pm
Sounds like a licencing issue. Have you had a cracked version of VDJ on your machine?
You will need to contact support as no-one of the forum can help with this: http://www.virtualdj.com/contact/step2.html
geposted Fri 03 Mar 17 @ 7:28 pm
no is not a cracked one, is the original one, recived when i bought the herculesrmx2
geposted Fri 03 Mar 17 @ 7:31 pm
It its Protection Error 4 the one you receive, then most likely its some "bad" entry in the Registries, left there from a previous VirtualDJ installation. You will need to clean your Registries from any VirtualDJ traces, using some Clean Registries Tool (Google it). If you dont know what you are doing or feel uncomfortable, contact Support
geposted Fri 03 Mar 17 @ 9:37 pm
thanks to you and technical support, the problem is solved!
Thanks again!
Regards
Thanks again!
Regards
geposted Thu 09 Mar 17 @ 6:00 pm
