Topic: Script School - Page: 45.15
just added in klaus' video on linked tracks to my feature post.
hi! i would button led on if in browser_window ‘folders’..folder have subfolders….and led off if it doesn’t;
my script: browser_open_folder off ? on : off
is not correct :( is there a script? thanks a lot
no the test for the bottom as I posted earlier only works in context of moving round folders, it doesn't work as a query.
thanks…is theren’t any solution? :(
There is one thing but it's more complicated than I can be bothered explaining in detail.
make a scroller, test for bottom, anything that opens add that header to a string variable, day to day use test if variable contains header in use.
You'd have to run the scroller any time you change folder layout.
PS please don't quote when it's obvious to whom you're replying to.
for my request i would use script: get_browsed_scrollpos
that is 0 only when cursor is in last folder 👍 but script:
get_browsed_scrollpos & param_cast ‘text’ & param _contains ‘0’
non work correctly :( could you help me? Tuanks!!
get_browsed_scrollpos & param_cast ‘text’ & param _contains ‘0’ works well for my request 👍
hi! i would all decks in beatlock with same masterdeck tempo, my script is:
-deck all beatlock on ? deck all beatlock off : deck all sync ‘masterdeck’ & deck all beatlock on
but doesn’t work :( could you help me?
thanks!
deck all isn't great for queries, query individuals, something like this
param_equal get_decks 4 ? param_equal `param_add "param_add 'deck 1 beatlock' 'deck 2 beatlock'" "param_add 'deck 3 beatlock' 'deck 4 beatlock'"` 4 ? deck all beatlock off : deck all beatlock on : param_equal get_decks 2 ? param_equal `param_add 'deck 1 beatlock' 'deck 2 beatlock'` 2 ? deck all beatlock off : deck all beatlock on :
or like this
deck 1 beatlock && deck 2 beatlock && deck 3 beatlock && deck 4 beatlock ? deck all beatlock off : deck all beatlock on
solved: my right script is:
deck all beatlock & deck 1 masterdeck ? deck 2 sync & deck 3 sync & deck 4 sync : deck 2 masterdeck ? deck 1 sync & deck 3 sync & deck 4 sync : deck 3 masterdeck ? deck 1 sync & deck 2 sync & deck 4 sync : deck 4 masterdeck ? deck 1 sync & deck 2 sync & deck 3 sync : nothing
I've asked you to stop quoting when it's clear whom you're replying to in this thread. Now I'm telling you, I will stop replying to you if I have to edit your posts again.
What's wrong with just?
deck all beatlock
It will sync from that
DECK ALL
A useful deck specifier for when you want all decks to do something but there are logical implications.
Check the var_list after pressing this button
deck all set result1 `get_deck` & set $result1 +1 & deck 1 set result2 +1
result2's value may come as a surprise, what's happened under the hood the script actually performed is this
( deck 1 set result1 `get_deck` & set $result1 +1 & deck 1 set result2 +1 ) &
( deck 2 set result1 `get_deck` & set $result1 +1 & deck 1 set result2 +1 ) &
( deck 3 set result1 `get_deck` & set $result1 +1 & deck 1 set result2 +1 ) &
( deck 4 set result1 `get_deck` & set $result1 +1 & deck 1 set result2 +1 )
It repeated the script for each deck so result2 is incremented 4 times
Playing with the logic, you can do something like this
make every other deck [other than the calling deck] play
set $deckvar `get_deck` & deck all param_equal `get_var $deckvar` `get_deck` ? : play_pause
Short and sweet,
If you need to use deck all for simple scripts there's no problem.
If you need deck all in more complicated scripts it's probably best to contain it in ( ) [deck specified in brackets only stay true inside the brackets]
There's probably some shortcuts here for complicated multideck scripts, just be wary, things can get confusing fast.
deck all beatlock
ok, i have understand, but i rewrite correct script for all users that have same request, ok? in all these pages (supreme blog for me!) i have read many and many script that have illuminated me for my personal mapper modifiers…and i think other members could make some thing…but if you don’t want these anymore, i stop post correct script, ok!
Thanks for all support Locodog 👍
deck all beatlock
…mmm not that i would…because ‘deck all beatlock’ sync other deck to the focused deck and not to the masterdeck..i wont masterdeck 👍 but i solved..thanks a lot
@mg_1978
You're wrong on several levels, but if you're not going to respect my request, I don't see why I should bother replying to correct you.
Hi!
virtualfolder_add ‘Sampler/Recordings’
why don’t work? Recordings is not a folder? 🤔 thanks a lot
A user requested this [make beatjump wrap round an existing loop]
Senky Dragon wrote :
Is there a way to make beatjump wrap round a loop?
If I set a 32 beat loop, am currently 28 beats through the loop, and jump forward 8 beats, I would expect to be on beat 4 of the existing loop.
I thought it kind of interesting
for jumping forward in the loop things to consider;
are we in a loop ? [if not nothing special needed]
is our jump bigger than the whole loop ? [idiot check, if true do nothing],
is our current position in the loop added to the beatjump, smaller than the loop size? [if so nothing special needed] [we get our position in the loop in beats by param_multiply get_loop loop_position]
if false do some math, our loop size * -1, added to beatjump gives us the amount we need to jump back. [wrap around]
a forward button it would be like this
loop 0 ? beatjump +1 : param_bigger get_loop beatjump ? nothing : param_bigger `param_add 'param_multiply get_loop loop_position' beatjump` get_loop ? beatjump +1 : param_add 'param_multiply get_loop -1' 'beatjump' & param_cast relative & goto
Backwards is a little different
mainly our wrap check, is beatjump value smaller than current loop position.
[if it is nothing special needed]
if false, our beatjump value * -1, added to our loop size is the amount we need to jump forward [wrap around]
a backwards button like this
loop 0 ? beatjump -1 : param_bigger get_loop beatjump ? nothing : param_smaller `param_multiply get_loop loop_position` beatjump ? beatjump -1 : param_add get_loop 'param_multiply beatjump -1' & param_cast relative & goto
Case of encoders it would be something like this.
[same as above combined, but also need to deal with the implicit of the encoder]
param_bigger 0 ? loop 0 ? beatjump +1 : param_bigger get_loop beatjump ? nothing : param_bigger `param_add 'param_multiply get_loop loop_position' beatjump` get_loop ? beatjump +1 : param_multiply 0 & param_add "param_add 'param_multiply get_loop -1' 'beatjump'" & param_cast relative & goto : loop 0 ? beatjump -1 : param_bigger get_loop beatjump ? nothing : param_smaller `param_multiply get_loop loop_position` beatjump ? beatjump -1 : param_multiply 0 & param_add "param_add get_loop 'param_multiply beatjump -1'" & param_cast relative & goto
Hi, I can't use JOG_WHEEL to smoothly change the position of the end of the loop section. Is there any option? Thanks
see the wheel_mode script
wheel_mode 'loop_out' ? wheel_mode 'loop_out,jog' : loop ? wheel_mode 'loop_out,jog' : loop_out
Already solved. Bye.
86%
