Dear Support,
I would like to make a filter folder that shows me all files who need tobe analyzed for STEMS.
(Like the filter option: isscanned=0)
Is that possible?
Is that possible?
geposted Fri 24 Jul 20 @ 2:02 pm
This is not currently possible.
Precomputing stems is only advised when your system is not able to compute quickly enough on-the-fly.
Also worth noting that if you precompute every file, you will need a lot of storage capacity to do so. The stems file is 2-3x larger than the original file and you must keep the original file too.
geposted Fri 24 Jul 20 @ 2:11 pm
Thanks for the reply, i didn't know STEM needed that much permanent space per (mp3) file.
If you have thousends of music files, you could run out of disk space.
I'm running VDJ on a Intel NUC with an i7 (7567U with no GPU).
An 3:35 min MP3 takes about 10 secs to analyze.
geposted Fri 24 Jul 20 @ 3:58 pm
Which is a quite acceptable time IMHO. So you should not pre-compute stems...
geposted Fri 24 Jul 20 @ 7:22 pm
This is what I did on my side to achieve this need (filtering on files from my iTunes/Music app folder only):
Precomputed Stems = 0 and File Path contains /users/nicolas/Music/MusicLibrary/
My next step is to find a way to filter tracks based on the stems:
- smart folder containing big vocal tracks
- smart folder containing instrumental-only tracks, ...
geposted Fri 16 Jul 21 @ 12:24 pm
Is this a feature now? I think I may have to precompute for stems 2.0.
geposted Thu 24 Nov 22 @ 2:48 am
DJ Heye wrote :
Dear Support,
Is that possible?
Is that possible?
geposted Thu 24 Nov 22 @ 7:15 am
Seems you are able to do this now very simply
geposted Fri 25 Nov 22 @ 3:27 am
