Forum: VirtualDJ Skins
Topic: EQ labels not working/updating correctly
nilaymkPRO InfinityMember since 2019
My config:
- Dual GPU, Intel i7 10710, 16GB RAM
- Win10 64 bit
- VDJ Pro Infinity 8.5 64bit 6334.
I distinctingly remember that the EQ knob labels changed based on the currently active eq_mode setting. (e.g. "High/Mid/Low" for frequency, or "Hihat/Mel Vox/Kick" for ModernEQ etc.).
But this has recently stopped working for me and it only shows me text labels 'High/Mid/Low" regardless of the EQ model. The issue seen on all modern skins (Default, Controller 2020 by DennYo, etc.) and occurs with or without controller.
P.s. All skins have be updated to their latest versions.
I've also double-checked the Skin XML code and all skins in question use 'high_label', 'mid_label' and 'low_label' textaction.
Any help appriciated.
geposted Fri 02 Apr 21 @ 11:54 am
Check that you have the stems mathengine enabled.
geposted Fri 02 Apr 21 @ 12:03 pm
