Every time I use VDJ default skin, I have to adjust the volume level, master volume level, and the right/left high/mid/low levels. It would be nice to be able to safe these setting, so that I don’t have to repeat this time-consuming task. Thank you.
geposted Mon 10 May 21 @ 8:24 pm
"normally" you play at full volume at the software.. .
And rather turn down your speakers / amp instead...
But if you prefer you can use the ONINIT entry in the keyboard mapper and set a start up value.
deck all level 70% & master_volume 70% ... for example
geposted Mon 10 May 21 @ 9:35 pm
