I start my sampler with a Drumloop via Controller-Button with
Leftdeck is masterdeck and the sampler is synced fine.
Now I start Rightdeck synced to Leftdeck and crossfade.
Stop Leftdeck.
Then I put Rightdeck as Masterdeck & Selected deck.
When I now change the tempo of Rightdeck the Sampler 7 should sync to it.
But it stays in tempo of Leftdeck although this is stoped and not masterdeck anymore and not even selected deck.
This is crazy. What to do?
(By the way: in Sample Editor the loop is set to "loop" and "Sync-Loc"
And please don´t tell me, the "Sync-Loc" is the problem, because I need this to
deck active sampler 7 play_stop
Stop Leftdeck.
geposted Sat 15 May 21 @ 10:52 pm
By the way: Sampler output is set to
(otherwise the loop would disapear with the crossfade to the right side)
Please help, I have really gigs in some days and spent MANY hours to move from
VDJ7 to VDJ8
I can´t move back now, this is too late.
(And these simple things worked always in good old VDJ7
Whether I started a loop from the controller or anywhere else, it always stayed in sync with the master tempo deck.)
I´m tired of all these little issues and bugs!
I want to stop having to reprogram everything and finally start making music again!
deck master sampler_output
VDJ7 to VDJ8
geposted Sat 15 May 21 @ 11:01 pm
Sorry, but how can a Sampler-Loop that is correctly set and synced to the master deck suddenly no longer be in sync simply because the master deck has changed?
Please help...
Please help...
geposted Sat 15 May 21 @ 11:05 pm
Crazy: When I start the sampler from the skin-sampler-pads it works fine.
geposted Sat 15 May 21 @ 11:10 pm
Seems to work fine here, but maybe I misunderstood a step you did ...
geposted Sat 15 May 21 @ 11:12 pm
