Hi,
Just starting using stems actively and noticed if I activate ⁶the vocal color fx in the computer (don't have it mapped to controller), the color fx knob on my ddj1000 didn't action the effect.
Few questions:
1) can I trigger the vocal color fx with a keyboard shortcut and have the color fx knob on the controller manipulate the fx?
2) my ddj1000 only has 4 color fx buttons, any creative ways to map the controller to use the all the native VDJ color fx?
Few questions:
geposted Sun 16 May 21 @ 8:44 pm
1) Try a keyboard key (or custom button) with the action:
deck all filter_activate 'vocals'
2) You can also change in the mapper and swap out one of the 4 presets.
Just search color_fx in the mapper search field and you will see what is what
Can also try map one of the button (or keyboard key) to : deck all filter_selectcolorfx +1
to cycle between. But not sure this one works, since the mapper is filter_activate. Worth a try
geposted Sun 16 May 21 @ 10:12 pm
