Forum: VirtualDJ Plugins
Topic: 6/29/21 Update STEMS does Not work!!
timecode does not scan song and stems is useless.
Default skin pro
geposted Wed 30 Jun 21 @ 7:21 pm
You likely are on a very old model of macbook then?
Check if mathengine got disabled in settings (if so you can set it back to CPU), or if very little ram, check if precomputeStems is set to "only use precomputed" (set to "create manually" instead), if you feel your computer is up for the task, and want to use as before.. ;-)
geposted Wed 30 Jun 21 @ 8:14 pm
