I have been using vdj b6609 new updated version, never happened before like this. I can not see any wave forms on both channels after 30 min of use, i had to restart vdj again in order to see those back. I got 2 wedding gigs back to back in next 2 days. Please help me!!
geposted Tue 24 Aug 21 @ 5:47 am
don't run beta software at a gig, go back 7!! releases to 6541 https://www.virtualdj.com/download/build.html
geposted Tue 24 Aug 21 @ 11:11 am
Just for the record I did a 3 hour set using b6606 with no problems at all using a dell 390 desktop.The picture posted showing the screen shot I noticed that the battery was showing 41% no power supply plug in and no waveforms it could be that as the battery runs down the machine shuts down certain things but saying that does the waveforms disapper when the power supply is pluged in?.
geposted Tue 24 Aug 21 @ 2:20 pm
Since it looks like both the overview and scratch waveform don't show, it could indicate some graphics driver problem.
geposted Tue 24 Aug 21 @ 2:31 pm
Check your graphics aren't going in to some hyper power saving mode on battery only.
geposted Tue 24 Aug 21 @ 2:43 pm
When I look at the photo.. It appears to me that... the 41% power level, is that of phone, used to take the photo, and may not be the battery level of the laptop running VDJ.
And I have had no issues with waveforms on the 6606 update, running it for hours.
geposted Tue 24 Aug 21 @ 4:06 pm
just had the same issue. in version 8 no problems. In version 2021 V8 . 5-64 B6747 I took the entire computer reloaded windows 10 and deleted all other programs and still got the same result. tried the roll back to 6541 didnt work .
geposted Sun 21 Nov 21 @ 10:44 pm
I'd be curious to see if you tried a different skin and see if you have the issue. Shouldn't be the skin but easy enough to see
geposted Tue 23 Nov 21 @ 1:39 am
The skin change didnt make a difference. What ever the issue is , version 8 works. Version 2021 not so much. anyone else have any ideas.
geposted Fri 26 Nov 21 @ 10:06 pm
solution , nvidia , go to configure sli, turn it to disabled , go to physx setting , processor select card like nvidia geoforce , apply, restart computer.
geposted Fri 26 Nov 21 @ 10:35 pm
