Hi,
I need help to create a custom button with the correct vdjscripts. Would appreciate help from any vdj sifu (master). I tried but in vain.
Thanks in advance.
Thanks in advance.
geposted Wed 06 Oct 21 @ 7:36 pm
There is already a pad dedicated to VintageView
https://www.virtualdj.com/plugins/index.html?addonid=81301
everything being controlled using variables it must be very simple
https://www.virtualdj.com/forums/235238/addons/VintageView.html
(as well, VintageView can be used as a standard skin, all needed scripting stuffs are in the xml file)
what are you trying to do exactly ?
geposted Wed 06 Oct 21 @ 8:33 pm
