For some weird reason, my virtual DJ restarts mid play when I’m djing. Usually after I touch any key on my keyboard or Numark Mixtrack Pro 3 controller. Sometimes, I can go hours without it and it finally happens. What might be the issue?
geposted Mon 29 Nov 21 @ 7:36 am
Starting now to have same problem, running b6921 arm om my MacBook Pro 2021 14inch. Did you solve it? Will running VDJ in rosetta help? Thank you, Tomas
geposted Mon 09 May 22 @ 5:56 am
Having the same problem
geposted Fri 13 May 22 @ 2:28 pm
